Old 02-15-2016, 06:22 AM   #1
bleox
Drives: 2015 Subaru brz
Jacking points?
So guys my jack is not long enough to reach the subframe the "low profile " jacks body will hit my bumper when I lower after I install my coils so my question is can I lift it right next to the pinch weld then put the jack stand next to it ? Or to make my life even easier can I just jack on side right in the middle of the pinch weld and do both sides ?
bleox is offline   Reply With Quote
Old 02-15-2016, 08:07 AM   #2
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Get some ramps, or make ramps out of wood. Drive the front onto the ramps for the extra height you need to fit the jack underneath.
MarkR171 is offline   Reply With Quote
Old 02-15-2016, 09:37 AM   #3
lukes Frs
Drives: 2016 Frs
Yea don't Jack the car up from the pinch welds they are really not designed to hold the weight of the car. Drive up on ramps an the go off the k members
lukes Frs is offline   Reply With Quote
Old 02-15-2016, 10:49 AM   #4
omfg5041
It's fine to lift by the pinch welds. It's what they're there for.
Sent from my Magic Unicorn using Tapatalk
omfg5041 is offline   Reply With Quote
Old 02-15-2016, 12:55 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Depends on what you are trying to do. You can use two jacks and lift one end of the car together, or you can even use a single jack and lift one side of the car as the chassis is quite stiff.
If you are doing this for purposes of lifting the car and working on the suspension, you'll find it best to lift one axle at a time. The sway bar will preload the suspension and make things difficult if one side is lifted and not the other.
Contrary to what you believe, the pinch weld areas are actual lift points for the car and can easily support the weight of the car.
-alex
Old 02-15-2016, 01:48 PM   #6
bleox
Jacking points?
Yeah my concern is that when I lower the car after suspension is installed the jack is not gonna make out its gonna get stuck because of deep in the subframe is my idea was to lift from the middle of the pinch weld of one side jack the whole side up put the jack stands then go to the other side
Old 02-15-2016, 03:21 PM   #7
lukes Frs
Drives: 2016 Frs
Look it up the pinch welds are nothing more than the visible area that the inerr structure weldsto the putter panel but have fun believing common miss beliefs in factors about you that knows for a fact that a pinch weld is for lifting a car look it up a pinch weld is only designed to support the load of the car when itis in pinch weld clamps on a frame machine. Justbecuse you work at advance auto or oriellys auto dosent mean your a car tech lol
Old 02-15-2016, 03:30 PM   #8
omfg5041
Dude, become a mechanic and then tell us that the pinch welds are not for lifting. You can lift any unibody frame by the pinch welds without doing damage to the vehicle. Granted, if they are soft and rusted, then no, don't do that. Since I don't have time to argue with stupid, it might help to look at the following forum link - http://www.ft86club.com/forums/showthread.php?t=10111
Old 02-15-2016, 03:55 PM   #9
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Floor jack will probably bend the pinch welds and the article says for factory scissor jack. My concern would be being so low I can't change a tire
RichardsFRS is offline   Reply With Quote
Old 02-15-2016, 04:10 PM   #10
omfg5041
Using a floor jack should not bend pinch welds. At the shop, all we lift by is pinch welds. at home, I lift by pinch welds without issue. It's a structural point of the body meant to support the weight. If you're really concerned, get a 1$ hockey puck, and set it on the floor jack. Problem solved. Same surface contact area, no risk of damaging paint.
Old 02-15-2016, 05:06 PM   #11
bleox
So can I jack it up from here
Old 02-15-2016, 06:13 PM   #12
mav1178
mav1178's Avatar
I would suggest you read the Owner's Manual on where the lift points are on the car.
And no, I am not a car tech nor do I work at Advance Auto or O'Reilly's.
And no, I am not the grammar police.
-alex
Old 02-15-2016, 06:19 PM   #13
mav1178
mav1178's Avatar
Here's the jack points:
http://s10.photobucket.com/user/azia...oints.jpg.html
Old 02-15-2016, 08:14 PM   #14
radroach
Drives: car
Originally Posted by mav1178 View Post
What is the "attachment" that is shown in those diagrams/illustrations? Is that basically a soft pad similar to the hockey puck method people are talking about?
Jacking points Qwimby2 BRZ First-Gen (2012+) — General Topics 4 12-08-2015 09:48 PM
Options for Jacking the Vehicle? Stang70Fastback BRZ First-Gen (2012+) — General Topics 15 06-27-2015 03:14 AM
Custom crash with jacking points? JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-07-2014 08:24 AM
Jacking a lowered BRZ/FRS? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-19-2013 02:04 AM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
