Old 03-18-2013, 05:51 PM   #1
swift996
swift996's Avatar
Jacking a lowered BRZ/FRS?
I'm awaiting my Eibach R2s but with my side skirts I was wondering if anyone is using something to assist in raising/lowering your car?
I was thinking of getting two planks of wood to drive onto/off of. Anyone have ideas? My jack is a low profile but the car might be too low to get it under after I install the coilovers.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-18-2013, 06:00 PM   #2
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
wood might be the best way, its what ive always used
SLICVIC is offline   Reply With Quote
Old 03-18-2013, 06:20 PM   #3
whataboutbob
AutoX-10/10ths every run
2 12 inch 2x4s here. Jack one end (front/rear) of the car at a time here.
Build thread:Here
Old 03-18-2013, 07:11 PM   #4
NemeGuero
This
NemeGuero is offline   Reply With Quote
Old 03-18-2013, 07:12 PM   #5
OrbitalEllipses
Drives: Attitude
Ground clearance stock 4.9". My jack's saddle height 4". My ground clearance after lip and springs: 2.9".
Don't like wood/ramps, so I'm selling my jack for a 2.5" saddle height jack. Most people won't do that and will opt low-pro ramps or wood planks to raise the car's ground clearance to something more friendly.
Old 03-18-2013, 07:30 PM   #6
swift996
swift996's Avatar
Thanks, that was what I had in mind..I didn't know if there was anything new on the market to solve this problem, good old fashion wood 2x4s work for me.
Old 03-18-2013, 07:34 PM   #7
whataboutbob
Yeah, it is kinda ghetto, but it works. :happy0180:
Build thread:Here
Old 03-18-2013, 07:54 PM   #8
wparsons
wparsons's Avatar
Old brake rotors work very well too if you have any of them kicking around.
flickr
Old 03-18-2013, 08:10 PM   #9
swift996
swift996's Avatar
Not a bad idea, I'll be pulling my OEM ones off very soon (just waiting on 4 bolts to arrive from Wilwood).
Old 03-18-2013, 10:14 PM   #10
OrbitalEllipses
Drives: Attitude
Tip: jack from the front FIRST. Jacking up the rear will lower and angle the front lip slightly and remove even more precious clearance.
Old 03-18-2013, 10:21 PM   #11
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
I'm getting tired of using the scissor jack, then my main jack, so might be looking at getting some of these:
http://www.raceramps.com/car-service-ramps.aspx
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Old 03-19-2013, 12:50 AM   #12
cnk
Drives: '13 DGM BRZ Limited
If you're using the scissor jack included with the car, be careful using it repeatedly like that. They are meant to be used for emergencies only and have been known to give out if used repeatedly in place of a real jack.
cnk is offline   Reply With Quote
Old 03-19-2013, 02:04 AM   #13
DNAPoPo
DNAPoPo's Avatar
Thanks, I only use it to get the car high enough for my main jack.
SoCal 86 OC Club
Safely Jacking and Supporting Your BRZ/FR-S GrimmSpeed DIY (Do-It-Yourself) Guides 152 06-11-2021 07:44 AM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
anyone with their car lowered ~2.8in! white86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-18-2012 11:54 AM
Jacking up car - using garage jack NYNOMAD BRZ First-Gen (2012+) — General Topics 2 06-27-2012 08:36 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
