Old 02-11-2016, 11:42 AM   #1
Riftur
Riftur's Avatar
disable the trunk release cancel button
Does anyone know of a way to disable the trunk release cancel button? My backup camera was installed where the keylock was and I am worried something in my trunk might hit the button on accident.
Riftur is offline   Reply With Quote
Old 02-11-2016, 11:43 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Unplug it
Old 02-11-2016, 12:15 PM   #3
kch
Senior Misanthrope
kch's Avatar
yep, unplug. super easy, 5 minute job.
edit: any reason why you didn't put it on the other side? that's where i did mine. took some drilling, but there's already a little indentation showing where the camera should go.
Old 02-11-2016, 01:17 PM   #4
Riftur
Riftur's Avatar
unplugging it does not work. As I just had to crawl through my backseats to pop the trunk. I really didn't want to make a hole in the car.
Old 02-11-2016, 01:22 PM   #5
Riftur
Riftur's Avatar
I popped the switch out and unplugged it. Did not work. Is there another way to unplug it?
Old 02-11-2016, 01:25 PM   #6
kch
Senior Misanthrope
kch's Avatar
So unplugging it makes the car think the button is pressed? That's unfortunate... I'm not sure what you can do, then.
Old 02-11-2016, 01:27 PM   #7
Riftur
Riftur's Avatar
correct. Not good
Old 02-11-2016, 01:29 PM   #8
kch
Senior Misanthrope
kch's Avatar
correct. Not good
cut a piece of plywood and block off that corner?
Old 02-11-2016, 03:01 PM   #9
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
I can think of two solutions:
1) move the backup camera
2) the trunk release control button is a toggle switch, I believe. That leads me to suspect that if you could find a way to provide constant power to the circuit in the absence of the toggle (i.e. replace the toggle connection with a constant power connection), it will work. There are wiring diagrams for the twins located somewhere in these forums - I am no electrician so I won't presume to actually be able to give you proper electrical advice. If this is indeed a reasonable suggestion, there are plenty of power wires around the trunk area from which you can splice into. Of course, I would be wary of 5V vs 12V supplies...not sure if that is even an issue in this case.
theadmiral976 is offline   Reply With Quote
Old 02-11-2016, 03:08 PM   #10
Tape a bottle lid over it so it can't get hit. This leaves the function should you want it don the road.
Old 02-11-2016, 03:20 PM   #11
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
and you have an extra bottle cap should you ever need one
fumanchu1 is offline   Reply With Quote
Old 02-11-2016, 03:44 PM   #12
swarb
If unplugging it doesn't work, you just need to complete the circuit and it will always be working.
FYI there is a key hole in the trunk...
Old 02-11-2016, 03:45 PM   #13
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I was going to suggest replacing it with a toggle switch with a toggle switch guard, but this is better.
jawn is offline   Reply With Quote
Old 02-11-2016, 03:46 PM   #14
jawn
jawn's Avatar
Is the lock cylinder on your trunk broken?
OEM illuminated trunk release button Guillaume Cosmetic Modification (Interior/Exterior/Lighting) 43 01-10-2018 05:02 PM
DIY: Trunk lid button for use with Easygo kit Chaetagnath DIY (Do-It-Yourself) Guides 1 08-03-2015 03:51 PM
Trunk opener button fitcious Scion FR-S / Toyota 86 GT86 General Forum 13 05-13-2014 01:24 AM
Trim removal - boot release button panel StuAU Cosmetic Modification (Interior/Exterior/Lighting) 2 02-04-2013 12:48 AM
Question for owners - Boot release button proficience AUSTRALIA 7 07-27-2012 11:12 AM
