disable the trunk release cancel button
Does anyone know of a way to disable the trunk release cancel button? My backup camera was installed where the keylock was and I am worried something in my trunk might hit the button on accident.
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#3 |
Senior Misanthrope
yep, unplug. super easy, 5 minute job.
edit: any reason why you didn't put it on the other side? that's where i did mine. took some drilling, but there's already a little indentation showing where the camera should go. |
#4 |
unplugging it does not work. As I just had to crawl through my backseats to pop the trunk. I really didn't want to make a hole in the car.
#5 |
I popped the switch out and unplugged it. Did not work. Is there another way to unplug it?
#6 |
Senior Misanthrope
#7 |
#8 |
Senior Misanthrope
#9 |
Drives: WRB Subaru BRZ Limited 6MT
I can think of two solutions:
1) move the backup camera 2) the trunk release control button is a toggle switch, I believe. That leads me to suspect that if you could find a way to provide constant power to the circuit in the absence of the toggle (i.e. replace the toggle connection with a constant power connection), it will work. There are wiring diagrams for the twins located somewhere in these forums - I am no electrician so I won't presume to actually be able to give you proper electrical advice. If this is indeed a reasonable suggestion, there are plenty of power wires around the trunk area from which you can splice into. Of course, I would be wary of 5V vs 12V supplies...not sure if that is even an issue in this case. |
#10 |
Tape a bottle lid over it so it can't get hit. This leaves the function should you want it don the road.
#11 |
Drives: 2013 Brz C38 (bought not built :P)
and you have an extra bottle cap should you ever need one
#12 | |
FYI there is a key hole in the trunk...
#13 | |
Drives: 2015 CWP BRZ Limited
#14 |
| OEM illuminated trunk release button | Guillaume | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 01-10-2018 05:02 PM |
| DIY: Trunk lid button for use with Easygo kit | Chaetagnath | DIY (Do-It-Yourself) Guides | 1 | 08-03-2015 03:51 PM |
| Trunk opener button | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 05-13-2014 01:24 AM |
| Trim removal - boot release button panel | StuAU | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 02-04-2013 12:48 AM |
| Question for owners - Boot release button | proficience | AUSTRALIA | 7 | 07-27-2012 11:12 AM |
