Old 01-28-2016, 08:51 PM   #1
Avion
Drives: 2015 BRZ Limited 6 Speed Auto
Harmonic Noise from rear Differential at 69 MPH solved
My Harmonic noise from the rear of the car was pinpointed to the rear Diff. They replaced the Differential and the Harmonic noise is 90% gone. The Service Manager said they pulled the magnetic plug and was full of destroyed material. They will send the differential to the engineers for analysis. I've seen on the forums that I have not been the only one with this problem. Also they said some rear diff noise is normal but mine was exceptionally loud.
Avion is offline   Reply With Quote
WTB: Stock LSD Rear Differential bshown Want-To-Buy Requests 0 01-24-2016 05:41 PM
How many of you guys actually get the rear deck rattle/clicking solved? lupindub Cosmetic Modification (Interior/Exterior/Lighting) 15 09-20-2015 09:30 PM
Rear Differential Oil Change - How Often? Euro7R Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 06-15-2015 10:08 PM
Eww rear differential goo LeeMaster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-10-2013 09:17 PM
Rear End/Gear/Differential Ratio fly2low Engine, Exhaust, Transmission 9 02-09-2013 11:53 AM
