Drives: 2016 BRZ Limited
Rattling noise on a stock BRZ?
The car only has 1100 miles on it but I've been noticing a very subtle rattling noise when I put my foot on the throttle. Is it just a BRZ internal part making noise and I'm not used to it? Or should I go to the dealer?
Only modification is Valenti tail-lights.
Valenti tail lights - Berk track pipe
Drives: BRZ Limited; GR86
If it's the interior then the dealer really won't help you. There are a few threads on here in which people have found where some of the rattling noise is coming from. if you can be more specific as to what you are hearing i can help you out a bit
It's a very low, almost metallic growl when you accelerate in the later gears. I'm not sure how better to describe it.
From the cabin, sounds like front.
a couple of things to check. make sure the dashboard is fully closed. it sounds silly but there are two points in which it locks it in place. second the seatbelt hinges rattle a bit at the point where it's connected to the body of the car. it took me a while to spot figure out where that rattle was coming from. make sure your rearview mirror is properly mounted and tightened. i had some rattling issues with that. these are all the things i would check. the rear has a lot of rattling noises too mainly the rear deck.
Also, make sure there is nothing in the glove box that is rattling.
humfrz |
Senior Misanthrope
That's what I was thinking. I've only been driving the car for a month so I thought it was just something I wasn't used to yet. Thank you!
#10 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Yea when the engine is under 2k, it sounds pretty rough. Almost like a puttering. You'll notice it when going slowly up hills too.
I usually drive at between 4k-5k RPM and I still get 19 avg MPG. Although my main reason for this is my exhaust drones like a mofo between 3k and 4k. But also, like previously suggested, make sure you dont have anything loose in the storage compartments (glove box, center console, storage area next to push button, bottle holders in the doors). Could also be the buttons on the seat belt guides if you dont fasten them (the little loops on the shoulder area of the seats) |
#11 |
Drives: Track preped NA FRS
Its the engine struggling with high load at low revs. This engine does not handle that well. High load at low revs is harder on the engine than revving it up to redline, just saying. Dont drive in the 1k-2k rpm range if you need to accelerate. Gear down, get up to the speed you wanted to be at, then gear up again, your car will thank you and you wont hear the noise.
#12 | |
#13 |
Drives: 2015 CWP BRZ Limited
#14 |
If you're referring to a diesel-like rattle when blipping the throttle right off idle up to about 1,500 rpm, it's totally normal. I'm not sure if it's tied to the crossover point between port and direct injection or simply the boxer configuration, but it's not a problem.
| The Following User Says Thank You to RJasonKlein For This Useful Post: | jcw99 (01-31-2016) |
| Tags |
| exhaust rattle stock |
| Loud Rattling Noise at Start Up | tomaszjanczak | Issues | Warranty | Recalls / TSB | 43 | 09-18-2014 08:50 PM |
| Rattling noise under Acceleration 5k RPM or more | phuthinhon | Issues | Warranty | Recalls / TSB | 5 | 05-12-2014 12:34 AM |
| Rattling noise at the rear. Not uniform, but happens often. | ZeHeadBanger | Issues | Warranty | Recalls / TSB | 7 | 10-22-2013 09:48 PM |
| Rattling Noise on acceleration | Naughty | AFRICA | 2 | 05-14-2013 11:17 AM |
| rattling noise in the trunk | ayetothejay | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-26-2012 11:19 PM |
