Old 10-21-2013, 12:53 PM   #1
ZeHeadBanger
Stuck like Glue
ZeHeadBanger's Avatar
Drives: WRB BRZ Limited
Rattling noise at the rear. Not uniform, but happens often.
I keep hearing a rattling noise at the rear, from behind the rear seats and somewhere close to the brake light inside the rear windshield. It's more like a metallic noise, as if some part is loose and rubbing against another metallic surface.
This does not happen every time I get into the vehicle, but happens often. It's random, doesn't happen at any particular speeds or anything like that.
After looking at possible sources, I think the following part might be the one that's causing it. This is on the driver's side, inside the trunk.
Could anyone please point out what is this? An alignment tab or a nut? If I isolate this (Dampen using a cloth or just hold it away from the metal part touching it), I do not hear the noise. (I simulated the noise by tapping on the metal body of the trunk, in the middle, next to the tabs).
Is this an easy fix or should I take it to the dealer? FYI, this is a BRZ Limited.
ZeHeadBanger is offline   Reply With Quote
Old 10-21-2013, 01:05 PM   #2
FR-S Matt
I watched someone actually bend that piece with some pliers and it solved it.
Old 10-21-2013, 04:31 PM   #3
ZeHeadBanger
Stuck like Glue
I was very close to do doing that yesterday, but wasn't sure what the tab was used for and decided against it. Has he had the problem ever since?
Also, do you know what that tab is for? Because I don't want to risk permanent
Thanks!
Old 10-21-2013, 08:23 PM   #4
FR-S Matt
Thanks!
No idea
Old 10-21-2013, 11:01 PM   #5
Ozzman
Drives: old
I think that is a locator tab for the upper child seat tiedown on that side.
Ozzman is offline   Reply With Quote
Old 10-21-2013, 11:18 PM   #6
cnk
Drives: '13 DGM BRZ Limited
Read here: http://www.ft86club.com/forums/showthread.php?t=42065
cnk is offline   Reply With Quote
Old 10-22-2013, 11:08 AM   #7
ZeHeadBanger
Stuck like Glue
Originally Posted by cnk View Post
Thanks! That's exactly the issue I'm having.
I should improve my searching skills!
Old 10-22-2013, 09:48 PM   #8
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
This car has more rattle than my old ass AE86.
Muaddib is offline   Reply With Quote
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
Rattling rear license plate bracket lucius AFRICA 11 12-03-2012 02:28 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
