Old 09-05-2014, 04:25 PM   #1
tomaszjanczak
Drives: Silver Subaru BRZ
Loud Rattling Noise at Start Up
Hello everyone!
Does anybody know what is making this noise whenever I start the car? The rattling goes on for a couple of seconds after starting. If I turn the car off and quickly start it up again, the noise doesn't happen. However, if I wait even 5 minutes after turning it off, the noise comes back when I go to start it again.
Someone told me its pre-detonation (knock) because of poor fuel. Not sure if that is the case.
Thank you!
[ame]http://www.youtube.com/watch?v=Dffoe78k14Q[/ame]
tomaszjanczak is offline   Reply With Quote
Old 09-05-2014, 04:31 PM   #2
tennisfreak
Drives: 2018 BMW M240i
Holy shit that sounds terrible.
If it was bad fuel why would the sound go away like that?
Old 09-05-2014, 04:54 PM   #3
tomaszjanczak
Because the computer senses the knock and adjusts the engine parameters for the lower octane fuel.
Old 09-05-2014, 06:43 PM   #4
D_Thissen
D_Thissen's Avatar
I'm not an expert so hopefully someone can chime in. I would think the knock wouldn't disappear shortly after start (since the fuel quality isn't changing).
Would it have something to do with injectors? Doesn't the fa20 start on direct then switch to the port? Again I might be mistaken (more than likely I am) so hopefully someone more knowledgeable will have an answer.
Old 09-05-2014, 06:48 PM   #5
tomaszjanczak
Would it have something to do with injectors? Doesn't the fa20 start on direct injectors then go to after it warms up switch to port injection?
I agree with you. I also thought knocking had a different sound than this. Not sure about the injectors but this happens when the engine is cold and when it is warmed up as well.
Old 09-05-2014, 09:01 PM   #6
roddy
roddy's Avatar
Drives: '13 Ultramarine
That sounds ugly. Definitely something I would want a dealer to look at. The sound seems to go away as the engine builds some oil pressure...cant really tell from the video, but it is likely either valvetrain related, or (gulp) the bottom end. Get it to a dealer. Just an opinion...others may vary.
Old 09-05-2014, 11:34 PM   #7
2013GTRNate
2013GTRNate's Avatar
Go to the dealership. There is nothing normal about those sounds. It sounds like the Pistons are rubbing on the cylinder walls. Terrible sounds are coming from your engine.
Good luck the dealership should make it right.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 09-06-2014, 12:20 AM   #8
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Damn that doesn't sound good. That is definitely not from bad gas. Have you checked your oil level lately?
Muaddib is offline   Reply With Quote
Old 09-06-2014, 02:38 AM   #9
EZWood
BAMF
EZWood's Avatar
Sounds like shit, when's the last time you changed your oil?
Old 09-06-2014, 03:01 AM   #10
litemup
Drives: around
I'm gonna go out on a limb. A/C compressor? Disengages after fault detect? No CELs?
litemup is offline   Reply With Quote
Old 09-06-2014, 06:55 AM   #11
tomaszjanczak
No CELs. AC works fine.
Old 09-06-2014, 06:57 AM   #12
tomaszjanczak
About 4 months ago (I go by months since I don't drive enough for the mileage count). I was actually planning on changing it today since I do it about every 4 months so I'll see if this somehow fixes the problem. Oil level has been good.
Old 09-06-2014, 06:58 AM   #13
tomaszjanczak
Yes, I regularly check it and it has been good throughout the 4 months since I last changed my oil. I'm planning on changing it today though.
Old 09-06-2014, 07:01 AM   #14
tomaszjanczak
You seem to be right about the built up oil pressure because if I turn the car off and immediately turn it on, the sound doesn't happen. But if I wait a minute and then turn it on, the sound happens. I do plan on taking to the dealer now, it sounds like a serious problem.
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 12:34 AM
Rattling noise at the rear. Not uniform, but happens often. ZeHeadBanger Issues | Warranty | Recalls / TSB 7 10-22-2013 09:48 PM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
