Old 01-26-2016, 12:14 AM   #1
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Oil Pressure Gauge
Been looking for a oil pressure gauge. I've actually tried a couple cheapo china ones and they did not read the signal from the pressure sensor at all or correctly. I would love to be able to log oil pressure parallel to my the data being recorded in my OFT, but I dont think it's possible.
Tried this one. looks awesome but it does not pick up the signal from the supplied pressure sensor (single wire): http://www.ebay.com/itm/251584094153...%3AMEBIDX%3AIT
This one look identical, but cost 3 times more: http://www.maperformance.com/product...FRRlfgodaZUIgA
Let's see what you guys are using for oil pressure readings!
Intent > Content
Old 01-26-2016, 12:51 AM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I'm using the Shadow Pro Gauge 2 "Perrin" oil pressure gauge. It works great. See my build thread for pics.
stockysnail is offline   Reply With Quote
Old 01-26-2016, 12:56 AM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I use defi, works great, matches the dash lights, highly recommended.
Decay107 is offline   Reply With Quote
Old 01-26-2016, 01:20 AM   #4
solidONE
solidONE's Avatar
Dang... ballers. I was going to cap my budget at $100 for the gauge. Maybe I should spend a bit more.
Intent > Content
Old 01-26-2016, 03:24 AM   #5
ryoma
ryoma's Avatar
defi is really nice, but expensive lol. I believe you also need to buy a control module along with a gauge
Old 01-26-2016, 04:20 AM   #6
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
I have an AEM oil pressure gauge, and it works perfectly.
crazyfrenchbiker is offline   Reply With Quote
Old 01-26-2016, 04:24 AM   #7
GT86_PRAGUE
Drives: GT86
It depends on version.
I have analog Defi gauges and no controller. Also no data logging.
GT86_PRAGUE is offline   Reply With Quote
Old 01-26-2016, 09:30 AM   #8
Ashikabi
Ashikabi's Avatar
I'm guessing all the big names line Defi, AEM, and Apexi will have top notch gauges. Gotta pay to play bro
Old 01-26-2016, 11:48 AM   #9
_gt86_user
Inactive
Drives: .
Been using the prosport "jdm" series w/ stepper motor for oil pressure, no issues here, although I have read issues where people got a faulty sender.
_gt86_user is offline   Reply With Quote
Old 01-26-2016, 04:48 PM   #10
solidONE
solidONE's Avatar
I like the pricing and look of the prosport gauges. Since they do have a warranty it shouldn't be too big an issue to replace the sender. I actually made a hookup to test the sensor using compressed air, so I can check it before I install.
Intent > Content
Old 01-27-2016, 08:56 AM   #11
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
STRi manufactures for Defi but is moving out of the US for distribution. A few places are blowing their old stock out: http://www.iagperformance.com/STRI-6...-p/xs6005a.htm
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 01-27-2016, 09:10 AM   #12
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I use VDO on my racecar and the datalogger just reads the analog voltage from the same spot as the gauge.
Then you need to figure out your own conversion coefficients.
justatroll is offline   Reply With Quote
Old 01-27-2016, 10:49 AM   #13
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I made a gauge pod out of aluminum and installed three 2 1/16" gauges. Oil Pressure, Boost, and Tranny Temp. Mine works really well except it's scary how low oil pressure gets at idle.
Lunatic is offline   Reply With Quote
Old 01-27-2016, 10:50 AM   #14
Ashikabi
Ashikabi's Avatar
That looks really good dude. Good job
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
DIY: mechanical oil pressure gauge litemup DIY (Do-It-Yourself) Guides 14 09-06-2014 11:12 PM
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 06:09 PM
