Old 01-22-2016, 03:35 AM   #1
Meanderchap
Drives: Scion FR-S Whiteout 6MT
225 enough tire for upgraded power?
Despite suggestions I've received to go for 17x9 RPF1s, I found a really good local deal on 17x8s, and I'm on a limited budget. About to pull the trigger, but the shop I spoke with tried to steer me toward 17x9 in the event I upgrade from stock power, so that I could run 245s.
Although I'll likely run stock power for a while, if/when I add some bolt-ons/cat-back/ECU tune or even FI down the line (unlikely), will I be limited with 225 width tires? Thanks.
Meanderchap is offline   Reply With Quote
Old 01-22-2016, 03:52 AM   #2
swarb
Tire compound is more important than width. If you aren't serious about tracking, 225 is more than enough. You can also fit 245's on 8inch width wheels. Read the specs from the tire manufacturer and decide which tires work best for your wheels.
The Following 5 Users Say Thank You to swarb For This Useful Post:
8R6 (03-01-2016), go_a_way1 (01-22-2016), Meanderchap (01-23-2016), nickmerronesucks (01-22-2016), Toyarzee (01-22-2016)
Old 01-22-2016, 03:57 AM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Must resist trolling urge...
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
go_a_way1 (01-22-2016), Toyarzee (01-22-2016)
Old 01-22-2016, 09:28 AM   #4
brianhj
Drives: 2017 Camaro 1SS
Lol I'm on E85 with Sprintex with Intercooler with 69mm pulley on stock wheels and original tires. It's fine
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
Old 01-22-2016, 01:48 PM   #5
strat61caster
strat61caster's Avatar
Eh, when I get out of autocrossing I'll probably sell my 17x9's and go to some 8 or 8.5" with 235 for a CARB supercharger (~230-240 whp), you're in California like me so you can run <200TW summer tires year round without issue. Maybe the car will be a little under-tyred, but I figure it will be like going back to stock with the Primacy's.
But that's just my hypothetical.
Edit: Wait, bolt-ons and tune only? Yeah 225 in a quality compound will be great. If you're in a position to start dropping $5k on FI then spend the money to get the right rubber once you've got experience and hopefully a bunch of people to copy.
Compound will be everything though, could end up with less grip than stock if you go cheap.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
freerunner (03-16-2016), Meanderchap (01-23-2016)
Old 01-22-2016, 01:51 PM   #6
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I've ran 225s on a car with 230 WHP and 300 lb/ft of torque. You can make it work with good compound.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Old 01-22-2016, 01:54 PM   #7
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
This i learned the hardway..bought some cheap 255s, still spin them like butter in 1st and 2nd.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
Old 01-22-2016, 01:58 PM   #8
DAEMANO
Time Traveller
At last measure I was at 233 WHP/ 217 TQ. I'm running 225 section (9" at the tread) BFG Gforce Sport Comp2s. For the street this is way more grip than is safe to explore in public.
For the track compound and tread width are much more important than section width. From what I understand, at our cars low weight, 225s could actually be optimal for the track. For AutoX I've read, the wider the tire, the better if you're trying to compete. For fun, it don't matta'.
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
Meanderchap (01-23-2016), Phantobe (01-25-2016), strat61caster (01-22-2016)
Old 01-22-2016, 06:31 PM   #9
makesdrivingfunagain
Compound is key!!! Their right.
makesdrivingfunagain is offline   Reply With Quote
The Following User Says Thank You to makesdrivingfunagain For This Useful Post:
Old 01-23-2016, 11:14 PM   #10
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
As others say, if you are sticking to NA power levels and low end forced induction, 225s in a good compound should be perfectly fine for anything you'll do. Also note that a 17x8 can take most 245 sized tires although this is not optimal for that rim width because sidewall flex reduces responsiveness a bit but is perfectly fine.
Lynxis is offline   Reply With Quote
Old 01-24-2016, 01:37 AM   #11
86Tony
Drives: 2015 AOZORA EDITION
255 is the way, thats the sweet spot for our cars.
86Tony is offline   Reply With Quote
Old 03-01-2016, 02:38 PM   #12
iccce34
Drives: 2013 FR-S and 2014 Jeep Wrangler
Even 225 bf Goodrich GeForce rivals I can't put alL my power down and putting 200 hp 160 tq to the wheels at the most. Great tires though. I have tried engaging tq gradually but still had grip issues.
K&n panel filter
Full exhaust
Manifold spacers
Aluminum driveshaft
Finanza flywheel
E85/tune
Sorry for the poor grammar, I'm typing on a tablet.
Not sure if this helps, just wanted to share my thoughts.
iccce34 is offline   Reply With Quote
Old 03-01-2016, 02:58 PM   #13
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
As most have mentioned in this thread, 225 is more than sufficient and if you decide you want more tire you can fit 245 size tires on the 8" wheel (verify with the specific tire brand/model).
As an aside, there is a difference in the way the wheel looks in a 17x8 vs a 17x9 which would be more of a deciding factor to me.
wheel directory for 17x8: http://www.ft86club.com/forums/showthread.php?t=37136
wheel directory for 17x9: http://www.ft86club.com/forums/showthread.php?t=15160
17x8
17x9
asdf is offline   Reply With Quote
Old 03-01-2016, 03:42 PM   #14
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Seeing a side by side difference sure rustles my jimmies. Gotta get that x9 fitment stat!
Kestrel is offline   Reply With Quote
The Following User Says Thank You to Kestrel For This Useful Post:
go_a_way1 (03-01-2016)
Aslking for recomendations on upgraded wheel/tire pairings for 2013 Scion FRS SnowCrash7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-16-2016 08:42 PM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 02:49 PM
86 upgraded plasma06 Scion FR-S / Toyota 86 GT86 General Forum 13 07-25-2014 01:47 AM
Upgraded Lighting on FR-S DarrenDriven Northwest 11 01-17-2014 04:46 PM
Cost of upgraded FRS ngabdala Scion FR-S / Toyota 86 GT86 General Forum 8 08-04-2012 04:38 PM
