Northwest AK, ID, OR, WA
Old 01-06-2014, 10:53 PM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Upgraded Lighting on FR-S
This was sent as a PM by @Hardpack, but it's better if everyone can help because I forget lots of stuff, haha!
Originally Posted by Hardpack
I have some questions about changing out some of the stock lights for my car. Iv'e been looking at alot of the posts on the forums as well as searching through youtube and vendor lights ie: Diode Dynamics and DDM Tuning.
1: For my low beams, are they just a plug and play with an HID kit?
2: For my high beams/DRLs if I wanted to put HIDs here would I need to install a projector?
3: If I wanted to turn my low beams into low/high beams what would that entail? If done, what would happen to my current high beams/DRLs?
4: Turn signals, fog lights, markers... I want to put LEDs here, are they just plug and play or is there anything else I need to do?
5: For interior lights, are those just plug and plays?
Any help at all would be really appreciated. Lighting is the next mod I plan to do to my car, and with a garage, I plan on painting my headlight housings red and my high beam reflectors black if I can manage to turn my current low beams into low/high beams.
1. Yup... I order my kits from hidextra.com and they are easy to install.
2. You can install HIDs in your high beams without a projector... it's basically the same as installing into the low beam. You should disable the DRLs be removing the resistor pack, though. (that is in the DIY section)
3. Talk to Kevin: @digital_assassin about the low beam projector conversion. He has done it and now his high and low beams are in the projector. It's pretty slick... you could even keep your regular high beams and have four bulbs lighting up the road.
4. For turn signals I would recommend using VLED's switchback bulbs. They run white when they are a parking light, then they turn orange when they flash. Very slick. You will also need their digital flasher relay so that you don't get speed blinkers when you convert to LED. The sidemarkers use peanut bulbs and LED bulbs are plug and play. Fog lights... well, I am using HIDs in my fogs... tried LED bulbs, but couldn't find anything reasonably priced that had the output I wanted.
5. Interior is plug and play.
Hope that helps!
Old 01-06-2014, 11:03 PM   #2
Hardpack
Drives: Raven black FR-S
My eventual plan is to bake the headlights and either paint them all red except for the high beam reflector which i would paint black, or just black them out completely. I think from what I saw on your video on youtube, painting the reflector pretty much makes that light useless.
Hardpack is offline   Reply With Quote
Old 01-06-2014, 11:29 PM   #3
DarrenDriven
NW Region Moderator
Yeah, haha, don't paint the high beam reflector if you want it to output any usable light. Oops.
Old 01-06-2014, 11:38 PM   #4
Hardpack
Another idea so I could paint the reflector was to do a retrofit kit to install a projector where the high beams go. This would allow me install HID high beams there as well as paint them for that black on red look I want.
Old 01-07-2014, 01:10 PM   #5
DarrenDriven
NW Region Moderator
I wonder if anyone has done that yet... seems like someone out there might have, but you could be the first.
Old 01-07-2014, 07:34 PM   #6
Hardpack
Yea I think it would be cool to have "reded out" headlights as opposed to the normal "blacked out" ones :P
Old 01-07-2014, 08:28 PM   #7
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
You mean like this?
https://scontent-b.xx.fbcdn.net/hpho...67849347_n.jpg
stockysnail is offline   Reply With Quote
Old 01-07-2014, 11:59 PM   #8
Hardpack
Originally Posted by stockysnail View Post
Yep, just like that. I think that would look awesome on a black car.
Old 01-08-2014, 03:33 AM   #9
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Rice
Chen is offline   Reply With Quote
Old 01-08-2014, 11:01 AM   #10
stockysnail
Just the tip
Originally Posted by Chen View Post
Rice
White, brown, jasmine, or basmati? Basmati has the lowest glycemic index and is the healthiest of the rices so I'll go with that.
Old 01-08-2014, 11:23 AM   #11
Boom
(Jo_o)J
Boom's Avatar
Drives: 2013 Raven FR-S
clearly jasmine rice
I like the tuna here
Boom is offline   Reply With Quote
Old 01-17-2014, 04:46 PM   #12
wrohdejr
Drives: 2013 subaru limited wrb brz
Well i just ordered one of the first Spyder headlights from ft86speedfactory. It will be shipped out on Monday. Guess the nw will get to see it first!!
Portland 86ers
wrohdejr is offline   Reply With Quote
DIY upgraded H9 bulbs for FRS owners post_break DIY (Do-It-Yourself) Guides 32 10-10-2015 10:52 PM
Upgraded Bespoke HU. Minovsky Electronics | Audio | NAV | Infotainment 3 08-04-2013 01:58 AM
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Does anyone have the factory upgraded stereo? redwing634 Electronics | Audio | NAV | Infotainment 8 08-22-2012 01:38 PM
Cost of upgraded FRS ngabdala Scion FR-S / Toyota 86 GT86 General Forum 8 08-04-2012 04:38 PM
