Wheel width: autocross vs track
Did some poking but didn't find what I wanted. Just need a confirmation on: same wheel(say rpf1) same tire(say rs3): wider better for autocross, skinnier better for track? That sounds right to you guys?
As a broad generalization, yes.
Another broad generalization would be what most people run in both situations. 17x9 +35 245/40-17.
Statement to add further detail for consideration
I suppose, would this offer any meaningful impact on performs either way or is it so minute as to be pointless and just get 9s
Drives: 2015 CWP BRZ Limited
The 9's look better, but I prefer the weight of the 8's and the broader choice of smaller tires. Narrower tires with closer-to-stock offsets feel more playful, too. As long as you get a tire with good compound, it'll be a substantial upgrade over stock, regardless.
I already run autocross with stock wheels and rs3s. But I want to go to the track a couple times this year so I was looking at better wheels. Probably wouldn't get anything until I wore out my rs3s but it never hurt to learn something new.
#10 | |
I personally like to pretend I have high skill(like Takumi) so I would go with the 17x9 +35 245/40 setup. |
#11 |
Miata traitor
Drives: 2002 Miata SE
e85 + header doesn't make enough of a significant difference in power to worry about needing wider tires.
If you want to split the difference, do the 17x9 and run a 235 tire. Or at least that's what I did. And like Jawn said, it does look better. |
#12 | |
#13 |
It also sounds like you're going to be autocrossing more than tracking, so I'd be inclined to run 17x9s like basically every one else in STX.
#14 |
17x9 +35 245/40 is THE one. Don't even consider anything else. All the big boys run this size.
| Spacers and Track width | tnle | Tracking / Autocross / HPDE / Drifting | 24 | 10-24-2017 03:28 PM |
| Best Offset/Width for autocross? | kuhlka | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-19-2014 03:14 PM |
| Track width | -max- | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-21-2012 06:37 PM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
