Old 11-01-2014, 08:57 PM   #1
tnle
Drives: Toyota 86 13'
Spacers and Track width
What's everyone thoughts on Track days and Spacers?
IMO the "theory" behind it sounds great, but response/feedback/drawbacks from experienced (track day) regulars would be awesome.
The idea atm is to buy RPF1s 17 x 8 +45 (because its affordable and it fits over the AP Racing Endurance)
Wrap them in sticky A050s or Z221 - 235 40 17
Then slap some 20 or 25mm spacers
My aim is to push out as much I can from these cars without putting down large sums of money.
Cheers
tnle is offline   Reply With Quote
Old 11-01-2014, 09:18 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The theory is simple: Don't.
What suspension deficiency are you trying to address with spacers? I ran 17x8" +44 without issues. 235/40-17 tires, too.
-alex
Old 11-01-2014, 09:23 PM   #3
tnle
high speed sweepers without dancing
Old 11-01-2014, 11:06 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The lack of information in your reply doesn't help.
Would you care to elaborate? What is your car doing that you don't like? What do you mean by "high speed" and "dancing"?
Old 11-01-2014, 11:41 PM   #5
tnle
Track - Winton Motor Raceway
Turn 5 to 6
130km/h give or take 5km/h (AD08Rs - 32PSI Hot) - high speed sweeper is just the name given to it
Dances - as in tail is in and out and I have to do micro corrections through it
I have 7 clicks down from the front and 5 from the rear because I like the over steer characteristics, I'm well aware this plays a factor in how it "dances" but the current settings suits the track
Experience level of the track - 5 with the 86
**I've driven a 34 GTR (400kg heavier) with less development time going through that same turn more stable and faster (yes I know these are 2 completely different cars)
Car Mods (in short)
UEL Headers (4 to 1) & Overpipe 2.5'
OFT Stage 2 UEL E85
Perrin Oil Cooler
Shockworks Coilovers (6f / 5r) - camber 3.4 front - 2.7 rear
Cusco Front Sway 20mm
Cusco Rear Sway 16mm
Cusco Rear Lateral Link - Lower Control Arms
Cusco Rear Lateral Link - Toe Arms
Cusco 4.556 Final Gears + Solid Pinion Spacer
Volk Racing TE37SL 18 x 9.5 +45
Yokohama Advan Neova AD08R - 255 35 18
Essex AP Racing Endurance Competition Brake Kit
Project Mu RC09 Club Racer (F1102) - Front / Rear
Old 11-01-2014, 11:53 PM   #6
tnle
I was actually more interested in the results/feedback of no spaces to spaces transition rather then "what my car doing that you don't like" hence why I tried not to mention it in my original post
I've added more information in the above comment
Old 11-02-2014, 01:25 AM   #7
jdmblood
jdmblood's Avatar
Drives: white subaru brz
The most popular fitment with the track guys seems to be a 17x9 wrapped in 245/45..17x8 with a 20mm spacer will have more poke than just a 17x9 if im not mistaken and I read somewhere that more poke creates more turbulence which in turn slows down the car.
jdmblood is offline   Reply With Quote
Old 11-02-2014, 01:45 AM   #8
tnle
I actually want 17 x 9 +35 RPF1 with no spacers to start off with, I tried asking the forum but never got an answer.
http://www.ft86club.com/forums/showthread.php?t=72989
* I am under the impression they would clear the spokes (because the sprint kit does) and the barrel (because they fit under the 17 x 8 +45) but this is theoretical, a solid image of an Endurance Kit or template behind a set of RPF1s 17 x 9 +35 would be awesome
RPF1 17 x 8 +45 was the on the official Essex fitment page
http://www.ft86club.com/forums/showthread.php?t=64282
Poke should be almost identical, the difference wouldn't be enough to disturb me.
Old 11-02-2014, 10:37 AM   #9
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
17x9 et 35 RPF1s clear the AP calipers by a narrow margin, but they clear. Just get those and 245/40/17 tires and call it a day.
Old 11-02-2014, 07:46 PM   #10
tnle
I had one of my mates check the endurance kit template behind his rpf1 17 x 9 +35, he said they do not clear the barrels
Old 11-03-2014, 10:55 AM   #11
wparsons
wparsons's Avatar
There are MUCH better ways to correct that than through increasing track width. Plus, 40mm of extra width probably isn't going to do anything for stability.
I would consider damper adjustments, camber/toe settings or a diffuser before resorting to spacers to correct instability.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
BRZ21 (11-06-2014)
Old 11-03-2014, 11:43 AM   #12
renfield90
The Stig's German cousin
While I agree that the OP should change the fundamentals in his setup first if he has a handling condition he doesn't like, I fundamentally and strongly disagree with this. In fact, the formula for Static Stability Factor uses track width as one of the inputs (the other being CG height).
There's a reason every major racing series has very strict limits on track width with big penalties for going over.
Old 11-03-2014, 11:51 AM   #13
DarkSunrise
DarkSunrise's Avatar
Isn't SSF a measure of rollover risk? I think OP is referring to high speed oversteer.
OP, if you like the car's balance in low speed corners and only want to increase high speed stability, I would think a rear diffuser (and possibly a wing) would be the way to do it.
2022 BRZ Build
2013 FR-S Build
Old 11-03-2014, 11:58 AM   #14
renfield90
You're missing my point, which is that saying extra track width won't help stability contravenes basic physics. It probably won't fix the OP's problem but this is an error of fact.
Tire Width? wootwoot Tracking / Autocross / HPDE / Drifting 84 03-06-2019 07:44 AM
Trackday Tires Width Alfalasy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-17-2013 10:46 AM
Track width -max- Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-21-2012 06:37 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
