Old 04-07-2012, 11:58 PM   #113
fatoni
Originally Posted by NESW20 View Post
what's wrong with downshifting?
Come to socal and spend three hours on the 91 everyday and you'll figure it out real quick
Old 04-08-2012, 12:14 AM   #114
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Like how much? 250? 280? 300? 350?
It all depends on the car and what I wanted out of it.
off subject but I wonder if the people that post here also realize that enthusiasts have modified the original 86 for more power as well. It's not like everyone that owned an original 86 has left it bone stock. But some people in this forum act like its blasphemy when others desire more power out of this new 86.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 04-08-2012, 12:16 AM   #115
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
been there, done that. i lived off the 91/57 for 20 years. believe me, i've had a very sore clutch knee after clutching in and out constantly for 2.5-3 hours when driving out to the norco/riverside area at about 4pm.
however, the situation you described has little to do with needing to downshift. that has to do with driving a manual transmission through stop and go traffic in general. would i enjoy it? absolutely not. no one in their right mind would. would it prevent me from purchasing a manual FRS/BRZ? no way.
for what it's worth, i occasionally drive a 1993 Corolla DX as a fuel saver/commuter. 115hp & 5 speed. i never have any trouble keeping up with or moving away from traffic in this area.
visual aid:
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 04-08-2012, 12:17 AM   #116
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
Originally Posted by Bristecom View Post
Interesting. I think I heard Toyota/Subaru may actually add a supercharger to the FA20? Do you think that would be a good idea?
Supercharging is more than likely not a good idea unless they drop the compression ratio down from 12.5:1. Then again, maybe that car has an over built top end, bottom end, internals, and an over-speced. fuel pump with plenty of over-head to handle the greater fuel requirements. Then again, again.... that all sounds like the recipe for a heavy car, an expensive car, or a heavy and expensive car... neither of which define the BRZ. Besides, Subaru already makes plenty of forced induction cars.
The goal of the BRZ is to be as organic as possible in terms of driver feel. For that, one would need a lightweight chassis and power-train, which provides linear and accessible power delivery. All requirements considered (cost, performance, manufacturability, serviceability, efficiency, packaging, weight, etc), that pretty much leaves you with a high revving naturally aspirated engine motivating a fairly light chassis riding on a good to fantastic suspension... cost dependent, of course. Without easing up on one of the above constraints (again unless it's cost), it is tough to beat the basic formula that the BRZ is built on. Case in point; though they seem different, the Porsche GT3, Ford BOSS 302, Mazda Miata, even the Integra Type R, and our very own BRZ really are fruit off the same tree.
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
Old 04-08-2012, 12:27 AM   #117
fatoni
visual aid:
it has a lot to do with downshifting. im not saying this car must have more power, im just saying that more power is helpful for a variety of every day tasks. for what its worth automatics downshift too.
on a side note, err, rather the original topic that has been buried in the typical ftclub tangents: does this review say that the frs is lighter than the miata? seems legit
Old 04-08-2012, 12:54 AM   #118
NESW20
2.1L 3SGTE
i guess i just don't mind downshifting as much as others. :happy0180:
the review does say that. and with some minor weight reduction...
2008 Civic Si Sedan
Old 04-08-2012, 12:56 AM   #119
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, I agree with that. So what do you all think about my proposal for a 2.5L Boxer 4? Generally I don't like Inline 4's to be over 2.0L because that means a balance shaft is required. However, Boxer engines have an advantage in that it does not need a balance shaft over 2.0L. So that kind of makes up for the fact that it needs two timing chains IMO.
A 2.5L boxer (with the same configuration as the FA20, ie. D4S) would only add a little weight, a little less fuel economy, and would not add anymore complexity. But the power gains would be big enough to give it the edge over any other NA 4 cylinder and the RX-8. Plus, it would have a more useable power range. So we're looking at about 250hp and 190 lb ft of torque.
BTW, this is probably going way off topic of this thread. :P
Bristecom is offline   Reply With Quote
Old 04-08-2012, 01:01 AM   #120
fatoni
It does say that. Both in the article and later in the spec comparison box at the end. I don't know why all these articles keep using the prht miata either. while you can probably pull more from the frs, the miata is going to be lighter mod for mod
Old 04-08-2012, 01:04 AM   #121
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Depends on now FA25 is made. FA20 been bored .5 or FA20 using same block as FA25. Those 2 makes a big difference in weights, hp/tq & fuel eco
Old 04-08-2012, 01:07 AM   #122
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Originally Posted by Sasquachulator View Post
Im curious as to what people who are considering the BRZ/FRS actually drive now.
If power is a major consideration it would put into perspective what they are coming from, whether its a 100hp slowass econobox tin can, a 300hp family car that has no semblance of driving feel whatsoever, a 300hp SUV that feels like its gonna tip over at a 1 degree turn, or a 600hp beastmode supercar that costs an arm, a leg, your first born, and your house.
I drive a 2002 WRX. Stock it dynos with the exact same numbers Cobb got when they dyno'd the BRZ, and it has 400lbs and 2 more wheels to drive. I have never felt like it was underpowered so I don't think I'll feel like the BRZ is underpowered.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 04-08-2012, 01:09 AM   #123
Bristecom
Bristecom's Avatar
Hey! You have a 2.5L NA Boxer 4. Tell us what you think? Nuff power? :P
How much does your car weigh? Around 2800 lb?
Old 04-08-2012, 01:28 AM   #124
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
As an owner of a NSX - I particularly took note of the "Verdict". I think this is going to be the perfect car for my Daily Driver!!!
-Jim
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
Old 04-08-2012, 01:32 AM   #125
Bristecom
Bristecom's Avatar
-Jim
What was more fun - the NSX or Elise?
Old 04-08-2012, 01:37 AM   #126
ichitaka05
Site Moderator
ichitaka05's Avatar
Stock or modded?
I'll give you both of em for ya
Stock EJ251
Low end got a ton of tq, so don't need to downshift at all
BUT top end don't got anything
Mid rpm got lil bump
Modded EJ251 (cams, valves, ported w remapped ECU, & usual bolt on mods)
Smoothed the bump in the mid
bumped extra 500rpm (but kinda pointless)
Top end gets better feel... but not great as S2k
STock EJ253
Don't have a ton tq feeling as EJ251 (due to chassis)
Top ends don't feel weak as EJ251, but 250rpm~400rpm to the redline still feel lacking
bump in the mid smoothed out, but still can feel it
Modded EJ253 (reflash ECU, usual bolt on mods)
Has better tq feel in mid high rpm than stock.
Top end lackness drop to only last +-200rpm
Wish for lil more tq line
My Impreza (GM6) weight 2718 lbs (track modded) to 2870 (stock). Prob current weight is 2750~2765 lbs-ish
My friend's Impreza ('07) weight currently 2950 lbs-ish
Overall my GM6 get's going enough for sure.
Nissan 370Z thread S2KtoFT86 Other Vehicles & General Automotive Discussions 116 04-07-2017 10:40 PM
FR-S vs. 370z, end all be all of discussions OldSkoolToys FR-S / BRZ vs.... 1491 09-25-2012 06:58 PM
BRZ vs 370z Video carbonBLUE FR-S / BRZ vs.... 48 04-17-2012 12:31 AM
FT 86 & 370Z similarities blur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-05-2010 12:39 AM
