Old 10-23-2012, 03:40 PM   #113
Ziptied
Information Guru
Drives: 95 Supra Turbo, 85 Corolla GT-S
Originally Posted by Grishbok View Post
loosely, a long block refers to the engine block, internals, the head, cams, and transmission. A 100% complete and total replacement
A short block is just the engine bottom end. Ive seen these terms used loosely so give or take some parts.
a trans is not a part of the engine, therefore not part of a long block assembly.
Ziptied is offline   Reply With Quote
Old 10-23-2012, 03:56 PM   #114
Ziptied
Information Guru
Balance has little to do with the failure causes. An L6 is naturally balanced.
Wait what? please stop talking. Balance can and does cause catastrophic failure ALL THE TIME. and an L6 is not "naturally balanced" stop reading things on the internet and facebook and believing them so someone who doesn't know anything believes this garbage. an IL6 is better for balance due to having an optimal crank length, but not "naturally balanced"
Old 10-23-2012, 07:46 PM   #115
Dimman
Kuruma Otaku
Dimman's Avatar
Alright, hotshot. Then please explain primary and secondary balance forces in motors and the effects of dampers vs undamped pulleys when it comes to the torsional forces a crankshaft sees.
That will certainly clear up some garbage.
Thanks.
Because titanium.
The Following 2 Users Say Thank You to Dimman For This Useful Post:
Gords_zenith (06-10-2013), ravenblackfrs (10-02-2013)
Old 10-23-2012, 07:46 PM   #116
motofan
Drives: 10 VW GTI
Originally Posted by rasec29 View Post
Got my car back Saturday! Yay thanks to Longo & Scion for getting done reasonably quick. They even reinstalled a new pulley and kept existing on the old engine for testing.
That is how a good dealer do things. Glad for you~
motofan is offline   Reply With Quote
The Following User Says Thank You to motofan For This Useful Post:
rasec29 (10-23-2012)
Old 11-23-2012, 04:23 PM   #117
CBR600RR
Drives: Raven Black
@rasec29 Any updates???
Old 11-23-2012, 04:57 PM   #118
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Can you tell us more details about your last oil change? Forget this pulley paranoia.
chulooz is offline   Reply With Quote
Old 11-23-2012, 06:13 PM   #119
rasec29
rasec29's Avatar
Drives: '09 xB & '13 FR-S
Car is running good, still have the cricket but never went in for the service for that.
Oil change was pretty standard, did it at Longo and they're pretty good with stuff. I think the tech that works on the FRS there has an FRS to. But haven't heard any updates from Toyota regarding cause.
Sent from my Galaxy Nexus using Tapatalk 2
rasec29 is offline   Reply With Quote
Old 11-23-2012, 10:14 PM   #120
fistpoint
Drives: Supercharged Golf Cart
Wait what? please stop talking....stop reading things on the internet and facebook and believing them so someone who doesn't know anything believes this garbage.
So we shouldn't bother reading your corrected statement then? Good advice.
fistpoint is offline   Reply With Quote
Old 11-25-2012, 11:44 AM   #121
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
they offered a rental by I have my xB to use in the meantime. I had Airaid intake and Perrin Pulley along with other cosmetic mods, those were the 2 mechanical.
Thanks guys, I trust Toyota will get me back or the road soon.
Didn't finish reading this whole thread, will continue after this post, but do you think the intake and pulley would void any warranty you had on it?
ravenblackfrs is offline   Reply With Quote
Old 11-25-2012, 01:48 PM   #122
Lonewolf
Lonewolf's Avatar
Drives: Moped
It didn't in this case since Scion did all the necessary repairs as warranty work...
Old 06-10-2013, 02:42 PM   #123
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Soooo the crank pulleys okay or not okay
Marcoscrdo is offline   Reply With Quote
Old 06-10-2013, 06:58 PM   #124
topazsparrow
Drives: slow
I'm pretty sure they wouldn't have put it back on the new motor if they had a suspicion that it was the cause of the failure.
topazsparrow is offline   Reply With Quote
Old 06-10-2013, 07:06 PM   #125
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I've got over 10k on my engine with the pulley.. Been at the track a few times and autoX no problems at all..
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Marcoscrdo (06-11-2013)
Old 06-11-2013, 12:22 AM   #126
Coastermikey
Drives: BRZ DGM
Service tech wouldn't tell me what happened but some other workers mentioned a problem with a rocker in the can shaft. Made a hole in the engine.
Back on the road, if hear anything new I will post up more info.
This is crazy I got a replacement long block not too long ago same symptoms and pop goes the motor. My service techs have refused to tell me what happened too. Even the engineers who flew out didn't say anything other than both cam shafts bent and broke through the valve covers.
Coastermikey is offline   Reply With Quote
2014 Subaru BRZ - Minor and Major Mechanical Changes WingsofWar BRZ First-Gen (2012+) — General Topics 53 12-28-2012 11:43 AM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-02-2012 12:45 AM
Dragster + hillclimb predictably ends in epic failure. old greg Other Vehicles & General Automotive Discussions 2 03-31-2012 11:48 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 01:25 PM
A pessimist's take on sales success / failure Mess11 Scion FR-S / Toyota 86 GT86 General Forum 137 11-24-2011 02:10 PM
