#1107 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
#1108 |
Drives: They have four wheels
A positive displacement supercharger should be much easier to calculate than any turbo rig. The prior posts make good points but I think some of you might be over thinking it in this case. I'd say around 260hp on E85 is more than logical.
The FA20 already makes 100hp/liter, that means it flows quite well. In a perfect world, w/ a PD charger you can simply take a percentage of 1bar (14.7 psi) that the stock motor operates at under NA and calculate the multiplier as a percentage of 1bar that you are adding. Assuming lack of intake restriction (Remember, the Innovate system comes w/ it's own tuned manifold). So let's say 7.5 psi is roughly 1/2bar, this translates to adding half your NA value, thus 200hp (crank) + 100hp= 300hp total (crank). However, if the Sprintex graph is right, then it operates at 90% volumetric efficiency, so more like roughly 100 x .90= 90hp (ignoring intake charge temps for the sake of simplicity). Thus total 290hp (crank). So now let's minus roughly 10% for parasitic losses = 260hp (crank). Minus another 15% for drivetrain losses and you are at 210-220hp (wheels). So take that 210-220 and add E85 to the equation and add maybe another 10% back, you get 230-240hp. So where's the 20hp discrepancy w/ robispec's numbers? Ah, we didn't calculate his increase in volumetric efficiency on both sides of the air pump due to improved intake and exhaust, better tuning/mapping, changed pulley/boost, reductions in frictional and rotational mass losses, all of which convert to more power. Thus finding another 20hp doesn't seem unlikely, nor would calling the dyno potentially generous be unreasonable. Either way, the numbers all look roughly in the logical ballpark to me. This is why I consider the rated HP rating of a blower and it's max BAR to be something of a red-herring. If I know it's volumetric efficiency, and the engine's VE, the math is relatively straight forward. To me, this does not look like unicorn numbers at all. If this were a turbo, the math is more complicated due to variable VE and intake charge temps. If the efficiency of the motor was lower, then yes I would see unicorns too. Imagine how well a PD charger would do on an S2000 at 120hp/liter. Common S2000 numbers seem to indicate an rough average of 330hp at the wheels under similar conditions. Again, this makes sense if you increase the FA20's efficiency by 20%. Could this Innovate PD charger get you there? That would be more of a concern for the S2000. These numbers aren't 100% accurate at all, but are relatively straight forward and in the ballpark of reality. So nobody should be worried about making only 180hp or hope for 600hp at the wheels w/ this kit. Last edited by Anaxilus; 06-20-2013 at 06:41 PM. |
| The Following 3 Users Say Thank You to Anaxilus For This Useful Post: |
#1109 |
Drives: A lot of supercars.
Boom.
#1110 | |
I don't understand the volume efficiency map. How would running say 10 or 12 psi plug into that calculation? (Assuming you can match the A/F) I guess the better question might be at what boost level is the blower maxed out at? (in theory)
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#1111 |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
245 was with an ok tune, and before that a different blower, 263/265 8.5 psi with stock fuel system being the thing that's stopping it going further, that's on 92 WAWA gas.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback Last edited by Adeets; 06-20-2013 at 07:24 PM. |
#1112 |
Drives: 2013 Black FR-S
#1113 | |
Am I surprised? No. I would expect the same with my innovate kit if I had a 9 psi pulley on 91 octane. This is why I am running water/meth and filling up with 2-3 gals of 100 octane at the track to keep everything working nice and smooth/cool and to create insurance. |
| The Following User Says Thank You to sw20kosh For This Useful Post: | Subzero (06-20-2013) |
#1114 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | sw20kosh (06-20-2013), whataboutbob (06-21-2013) |
#1115 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | sw20kosh (06-20-2013) |
#1116 |
Drives: WRB BRZ
was MIA for like 3 weeks from the forum come back to find kit still not released! LOL im going turbo. screw this.
#1117 | |
OEDC
Oh and I don't need to know second hand about something some guys car did, this is my car.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
#1118 | |
No offense.
#1119 |
Drives: Scion FR-S
I'll have the kit in Michigan with 93 octane. Some gas stations there sell 91 and 93 octane. do you think it would be a noticeable difference between the two. E85 is plentiful in Michigan so I plan on running that eventually but I will probably leave it on pump gas for a bit just wondering if I should put 93 in it or go with the kit recommended 91.
#1120 |
Drives: Attitude
| Bullet/Sprintex/Innovate on the bullet website | JoeBoxer | Forced Induction | 333 | 04-18-2013 11:07 AM |
| Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 11:32 AM |
| Bullet SC 86 | Loki556 | AUSTRALIA | 9 | 08-08-2012 02:39 AM |
| Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 05:40 PM |
