#99 | |
Drives: 2013 frs whiteout
The offset kinda killed it for me ...if he only had the 35 offset Thanks though |
#100 |
How about going 16 but wide with just a bit more sidewall..anybody thinking of doing these
#101 |
Drives: FR-S 6MT
Noob looking for some friendly advice on tire + wheel sizing:
note: I'm planning to drop my FRS 1 inch on springs 1) Wheels - I'd like the same size on all 4 wheels and i'm choosing between these 2 sizes 18x8.5 18x9 I know they have different offsets but which will be closer to an "ideal" fit. Does it even matter considering there are apparently ways to adjust the fitting? (spacers, etc stuff i dont know much about) 2) Tires I understand tires can be stretched with the potential risk of safety/performance (i'm not trying to dredge that argument up) but for the two sizes above what are the ideal tire sizes I should try to find? ie. 225 vs 245 vs 235 maybe? 3) Are these wheels/tires so large (particularly for the front) that the stock drivability of the car is highly impacted? I only know how the car feels like in stock form right now. Thanks for all the great info in support of the less informed community |
#102 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
![]() Wheel width: choose your wheel width based on the tire you want to use. In other words, if you want to run a 215, don't buy a 9" wide wheel it's unnecessary weight. 215, 225, 235, 245 all fit an 8-8.5" wheel fine. A 9-10" wheel is not necessay unless running 255+. Too much wheel (width/weight) and too much tire will "ruin" the nimble feel of the car. Street application would not require more than 225 at stock power levels. Track work is another story. You are balancing grip for weight and driveabilty.
![]() "The best track modification you can ever make is between the steering wheel and seat." - CSH |
#103 |
Drives: Scion FR-S
17x8 +35 how will they look, lowered on KW v3s???
#104 |
Drives: raven fr-s
for you wheel guru's, i have been searching for a couple days and have made a final choice on a set of wheels. the front wheels are 18 x 8.5 (5 x100) with a +35 offset. the rear is 18 x9.5 with a +40 offset. any recommendations on tire size? and will there be any issues with fitting these wheels. i would prefer not to stretch the tires..all suggestions and advice is appreciated....
The Following User Says Thank You to five-0 For This Useful Post: | shu5892001 (09-24-2012) |
#105 | |
Drives: iG FR-S
Front size 235-245 Rear size 255-265
#106 |
Drives: raven fr-s
#107 |
Drives: Some rust bucket
Volk CE28N 17x7.5 +44mm or +50mm offset
What would be the pros and cons between the CE28N 17x7.5 +44mm and +50mm offsets? I'm not concerned about looks as I'm more concerned potential rubbing, performance benefits, etc.
#108 |
Black Blood of the Earth
Drives: The Porkchop Express
I have 17x7.5 te37 +48 and they have caused me no problems with rubbing. I think someone on here figured out the sweet spot is 17x9 +35 for perfect flush fitment.
It's all in the reflexes.
#109 | |
i'm not going for the flush fitment as you can tell by going with 17x7.5 wheels. i'm guessing the 50mm offset would give me the closer to OEM fitment? they're 0.5 wider than OEM wheels but are 2mm closer towards the inside of the car. can you even compare offsets of 2 different wheels? |
#110 |
Drives: '13 BRZ Ltd WRB
Yes, very close to OEM. I believe 53mm on a 7.5" width would place the outside edge at the same point. Yours will stick out 3mm on the outside and 9mm on the inside, vs. stock. Plenty of room.
#111 | |
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
Check out this illustration. ![]() |
The Following User Says Thank You to Mark Slide Squad For This Useful Post: | ayau (09-25-2012) |
#112 | |
here's how i calculated it. to keep things simple, i converted both wheels to mm. OEM 7 in. = 177.8mm CE28N 7.5 in. = 190.5mm the two wheels are 7.5 in. + 50mm and 7 in. + 48mm. center lines of both wheels: OEM = 88.9mm CE28N = 95.25mm add the offsets (mounting location): OEM = 88.9mm + 48mm = 136.9mm CE28N = 95.25 + 50mm = 145.mm we now know where the hub is in relation to the wheel per the above calculation. take the total width subtracted by the mount locations to get the distance from the mount location to the outside wheel. OEM = 177.8mm - 136.9mm = 40.9mm CE28N = 190.5mm - 145.25mm = 45.25mm the difference between the two numbers will tell you how much wider the ce28n is when it's mounted to the hub. correct me if i'm calculating this completely wrong. |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
