Old 09-16-2012, 12:40 PM   #85
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Originally Posted by lookchris View Post
Should fit real well bro I'm actually going for the same fitment.
Are you planning on lowering your car as well?
i def want to but thats in the future, what size tire you think would go best ?
ScionFR-S is offline   Reply With Quote
Old 09-16-2012, 12:57 PM   #86
lookchris
lookchris's Avatar
I was planning to rock 225/40
lookchris is offline   Reply With Quote
Old 09-16-2012, 01:57 PM   #87
2pt5RS
Berz
on a 9" wide wheel?
2pt5RS is offline   Reply With Quote
Old 09-16-2012, 02:44 PM   #88
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Go with a 245/35 is you're running 18s.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 09-16-2012, 03:26 PM   #89
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Just wanted to check, did you post the right link? That could be causing the confusion with sizing, or did the op really mean 18x9 ? Just wondering since the link isn't for Rota Grids...
Ravenlokk is offline   Reply With Quote
Old 09-16-2012, 05:00 PM   #90
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
The subject line says "Rota Grid" and the link is for "Rota G-Force" The wheel you linked will fit your car. Just understand it will "poke" out much further than stock wheel offset.
Old 09-16-2012, 06:23 PM   #91
ScionFR-S
ScionFR-S's Avatar
Im sorry guys i meant to put Rota G-Force, im going to go with a 245/35 most likely and as long as i get no rubbing issues im satisfied... do you think it will stick out too much that it wont look appealing anymore lol?
Old 09-16-2012, 07:03 PM   #92
camelflage
Drives: pinto power
well, do you like to look of flush wheels with slightly stretched tires? thats all that matters, cause its your car. 245/35 on a 9" wheel is going to be just a bit of stretch.
camelflage is offline   Reply With Quote
Old 09-17-2012, 02:30 AM   #93
BlaineWasHere
Grip>Drift
Drives: FRS
I'm running 17x9 with 245/40/17 but ET42 VS 35.
This would be almost exact same size as 18x9 with 245/35/18.
Check my build thread link in my sig for pictures of how that fits in the fender to decide if you want a little more "poke" or not.
Old 09-17-2012, 05:43 AM   #94
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
18x9 +35's going to poke unless he has a drop + camber...
dunno, I'm not a fan of poke. poke is the enemy.
to @ScionFR-S keep in mind his car can look like that because he has coilovers
The real issue here is that you asked for 'the best fitment', but nobody asked you 'for what'? Are you doing performance driving on these wheels? Or do you just want the 'look'? Are you getting springs or coilovers or staying stock?
Originally Posted by 2pt5RS View Post
on a 9" wide wheel?
something wrong with him wanting to stretch tires? some people want that look.
for reference, this is a 225 on a 9" (happens to be +35 too)
http://www.ft86club.com/forums/showp...93&postcount=1
dori. is offline   Reply With Quote
Old 09-20-2012, 11:55 AM   #95
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Is it possible to fit 17x9.5 +45 in front without a spacer ?
adprokid is offline   Reply With Quote
Old 09-20-2012, 09:34 PM   #96
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Xxr 527 staggered 18x8.75 and 18x9.75 Offset +20 all around
Planning to lower them on coilovers (kw v3s)
Will I have clearance issues with these ..
Thanks
Ad8707 is offline   Reply With Quote
Old 09-20-2012, 10:15 PM   #97
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Thanks
That fitment is very aggressive.
50 & 63mm outward vs oem spec.
Inner clearance not an issue.
Major camber, roll and pull recommended for fitment.
I wouldn't run that without an over-fender kit.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Ad8707 (09-20-2012)
Old 09-20-2012, 10:37 PM   #98
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Thanks
I just posted pics of the 530 in +35 all the way around no way i would consider +20.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
