Old 09-20-2012, 11:52 PM   #99
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Originally Posted by ill86 View Post
That fitment is very aggressive.
50 & 63mm outward vs oem spec.
Inner clearance not an issue.
Major camber, roll and pull recommended for fitment.
I wouldn't run that without an over-fender kit.
Yeah I was just trying get rims from local sale and he was selling them cheap.
The offset kinda killed it for me ...if he only had the 35 offset
Thanks though
Ad8707 is offline   Reply With Quote
Old 09-21-2012, 04:00 PM   #100
Ad8707
Ad8707's Avatar
How about going 16 but wide with just a bit more sidewall..anybody thinking of doing these
Old 09-21-2012, 07:25 PM   #101
Maddjester
Drives: FR-S 6MT
Noob looking for some friendly advice on tire + wheel sizing:
note: I'm planning to drop my FRS 1 inch on springs
1) Wheels - I'd like the same size on all 4 wheels and i'm choosing between these 2 sizes
18x8.5
18x9
I know they have different offsets but which will be closer to an "ideal" fit. Does it even matter considering there are apparently ways to adjust the fitting? (spacers, etc stuff i dont know much about)
2) Tires
I understand tires can be stretched with the potential risk of safety/performance (i'm not trying to dredge that argument up) but for the two sizes above what are the ideal tire sizes I should try to find? ie. 225 vs 245 vs 235 maybe?
3) Are these wheels/tires so large (particularly for the front) that the stock drivability of the car is highly impacted? I only know how the car feels like in stock form right now.
Thanks for all the great info in support of the less informed community
Maddjester is offline   Reply With Quote
Old 09-21-2012, 11:35 PM   #102
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
18x8.5
18x9
2) Tires
A brief reply from my phone. I apologize for not giving a lengthy reply.
Wheel width: choose your wheel width based on the tire you want to use. In other words, if you want to run a 215, don't buy a 9" wide wheel it's unnecessary weight.
215, 225, 235, 245 all fit an 8-8.5" wheel fine.
A 9-10" wheel is not necessay unless running 255+.
Too much wheel (width/weight) and too much tire will "ruin" the nimble feel of the car. Street application would not require more than 225 at stock power levels.
Track work is another story. You are balancing grip for weight and driveabilty.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-23-2012, 10:46 PM   #103
87Turbo
Drives: Scion FR-S
17x8 +35 how will they look, lowered on KW v3s???
87Turbo is offline   Reply With Quote
Old 09-24-2012, 05:41 PM   #104
five-0
five-0's Avatar
Drives: raven fr-s
for you wheel guru's, i have been searching for a couple days and have made a final choice on a set of wheels. the front wheels are 18 x 8.5 (5 x100) with a +35 offset. the rear is 18 x9.5 with a +40 offset. any recommendations on tire size? and will there be any issues with fitting these wheels. i would prefer not to stretch the tires..all suggestions and advice is appreciated....
five-0 is offline   Reply With Quote
The Following User Says Thank You to five-0 For This Useful Post:
shu5892001 (09-24-2012)
Old 09-24-2012, 08:03 PM   #105
ill86
ill86's Avatar
Drives: iG FR-S
Yep, they will fit.
Front size 235-245
Rear size 255-265
Old 09-24-2012, 09:50 PM   #106
five-0
five-0's Avatar
Drives: raven fr-s
Yep, they will fit.
Front size 235-245
Rear size 255-265
thanks....
Old 09-25-2012, 07:33 PM   #107
ayau
Drives: Some rust bucket
Volk CE28N 17x7.5 +44mm or +50mm offset
What would be the pros and cons between the CE28N 17x7.5 +44mm and +50mm offsets? I'm not concerned about looks as I'm more concerned potential rubbing, performance benefits, etc.
Old 09-25-2012, 07:35 PM   #108
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
I have 17x7.5 te37 +48 and they have caused me no problems with rubbing. I think someone on here figured out the sweet spot is 17x9 +35 for perfect flush fitment.
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 09-25-2012, 07:39 PM   #109
ayau
thanks! is it pretty close to the OEM fitment?
i'm not going for the flush fitment as you can tell by going with 17x7.5 wheels. i'm guessing the 50mm offset would give me the closer to OEM fitment? they're 0.5 wider than OEM wheels but are 2mm closer towards the inside of the car. can you even compare offsets of 2 different wheels?
Old 09-25-2012, 07:51 PM   #110
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Yes, very close to OEM. I believe 53mm on a 7.5" width would place the outside edge at the same point. Yours will stick out 3mm on the outside and 9mm on the inside, vs. stock. Plenty of room.
2point0 is offline   Reply With Quote
Old 09-25-2012, 08:00 PM   #111
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
You can't compare offsets if the rims are different widths. For example, a "zero" offset wheel would have the hub mounting surface of the wheel (the face that goes against the brake disk face) centered perfectly in relation of the width of the wheel. So for example, on a 7" wide wheel, 3.5" would be the theoretical center point where offset is called out from. A positive offset means that the hub mounting surface is pushed toward the outside face of the wheel, which means the wheels are pushed in more toward the suspension. A negative offset means that the hub mounting surface is more toward the inside face of the wheel, which pushes the wheel away from the suspension more (hellaflush! haha). So for example, if a 7" wide wheel has an offset of +40mm, that means the hub mounting surface is 40mm off perfect center (3.5") of the 7" width in the direction toward the outside face of the wheel. Let's compare a 7.5" wide wheel with the same 40mm offset. The perfect center of the 7.5" wide wheel is going to be 3.75" from the edge of the wheel, not 3.5" like the 7" wide. This means that you will have more of a "lip" on the 7.5" wheel, by .25" or roughly 6mm in metric. I hope all this makes sense.
Check out this illustration.
Mark Slide Squad is offline   Reply With Quote
The Following User Says Thank You to Mark Slide Squad For This Useful Post:
ayau (09-25-2012)
Old 09-25-2012, 08:36 PM   #112
ayau
what do you mean that you can't compare the two wheels if they're different widths? i believe you can at least get the measurements on how much wider the ce28n is on the inside and outside compared to the OEM 7 inch wheel. as long as my algebra is correct, i calculated that the 7.5 inch wheel will be 4.35mm wider on the outside and 8.35 wider on the inside. 4.35mm + 8.35mm = 12.7mm = 0.5 inch.
here's how i calculated it.
to keep things simple, i converted both wheels to mm.
OEM 7 in. = 177.8mm
CE28N 7.5 in. = 190.5mm
the two wheels are 7.5 in. + 50mm and 7 in. + 48mm.
center lines of both wheels:
OEM = 88.9mm
CE28N = 95.25mm
add the offsets (mounting location):
OEM = 88.9mm + 48mm = 136.9mm
CE28N = 95.25 + 50mm = 145.mm
we now know where the hub is in relation to the wheel per the above calculation.
take the total width subtracted by the mount locations to get the distance from the mount location to the outside wheel.
OEM = 177.8mm - 136.9mm = 40.9mm
CE28N = 190.5mm - 145.25mm = 45.25mm
the difference between the two numbers will tell you how much wider the ce28n is when it's mounted to the hub.
correct me if i'm calculating this completely wrong.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
