Old 04-18-2012, 09:47 PM   #85
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
I believe you guys are missing the whole point here. Regardless of the difference in the springs they are showing that the FRS/BRZ can be driven either way with minimal time loss. The fact that the FRS was slightly faster while oversteering doesn't mean one is better DD or edgier.
TRD_07 is offline   Reply With Quote
Old 04-18-2012, 10:02 PM   #86
fatoni
these cars are too similar to even pretend to draw any conclusion as to what is faster. you could probably use the same car for two laps and get an equally large time gap. i find it funny that people even care since if you valued objective performance stats at all, this wouldnt be the car for you
Old 04-18-2012, 11:14 PM   #87
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Originally Posted by yajin View Post
True, I like his driving too. They say Nakaya's technique is more strategic compared to how Tsuchiya drives in a more touchy-feely way.
Taku Sato is the one of the first students at Nakaya's class and the best ever F1 driver from Japan.
I think Kamui Kobayashi is the best F1 driver fron Japan.
Hanzo is offline   Reply With Quote
Old 04-19-2012, 11:45 AM   #88
SnapOv3st3r
Drives: 400whp Scion tC
Very nice vids. Was interesting to read the little criticism towards the driver of the BRZ, but some people didn't realize it was the same guy...lol
SnapOv3st3r is offline   Reply With Quote
Old 04-19-2012, 01:16 PM   #89
meanmud
Drives: Fiesta
Originally Posted by carbonBLUE View Post
a normal person wouldnt be able to sense brake fade till about 8th-10th hot lap, and mainly because a normal driver doesnt know how to push a car that hard...
Not necessarily true - a normal person will cook brakes faster out on track due to poor technique.
meanmud is offline   Reply With Quote
Old 04-19-2012, 01:28 PM   #90
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
yes that also is true
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 04-19-2012, 07:06 PM   #91
takchi
Drives: s2000
Both cars are prepped up to be slightly different in terms of what market they're trying to aim towards. The BRZ appears to be more stable thus less steering input is required. I'm thinking this setup is very good for high speed corners. I still don't like how much understeer seems to be dialed in. This might be for safety reasons?
The GT86 is very fun looking, yet still pumps out a pretty fast time compared to the BRZ. I'm thinking this car is setup more towards the neutral side compared to the BRZ, but requires faster steering input to catch the car while going fast. Either way, I like how both cars perform. With a set of brake pads and fluid, both cars should be a blast to drive. Besides, all cars fade their brakes on the track with OEM equipment. Be smart and get good track pads and DOT4 fluid. Having some good tires like the Dunlop Z1SS, Hankook RS3, Bridgestone RE11, or Advan AD08 would certainly spice up the cornering ability as well as fun factor on track. Heat is going to destroy those Prius tires! Don't forget tire pressures play an integral part on how the car handles as well!
Also, Nakaya is a great driver. Time will tell as to what refinements Toyota and Subaru will make to make this car even faster around Tsukuba. As everybody knows, balance (suspension/tire setup, aero, and lastly, power) is more important at Tsukuba than other tracks.
takchi is offline   Reply With Quote
Old 04-19-2012, 07:56 PM   #92
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Originally Posted by AX_FRS View Post
Wait, didn't someone else just say the BRZ has stiffer springs? Anyone actually know what the spring rates are supposed to be? Or something more definite?
i remeber from one review a while back that the brz has understeer and the frs has balanced handling and a stiffer ride, subaru is known for a softer ride, might have been dsport mag when they tested 4 models.
i dont know the exact specs though
Old 04-19-2012, 11:14 PM   #93
fatoni
the thing about neutral is that it isnt a side really but the middle
Old 04-20-2012, 02:13 AM   #94
Grip Ronin
The Mechanic
Grip Ronin's Avatar
im not worried at all about the stock set up because there will be coilovers on mine within a couple months of purchase
Old 04-20-2012, 11:17 AM   #95
takchi
Drives: s2000
The car certainly isn't super oversteer happy because the power can be put down. This is a little shocking especially since cars from factories always have a alignment set or suspension setup dialed in for understeer. I personally track a non-staggered tire setup S2000 and right now the car is right in between the BRZ and FRS in terms of how much steering input is required to complete a corner. I'm very curious as to how the suspension will take grippier tires though. How much more is it going to roll? Is that roll going to affect how much grip you can get from the tires? There is a S2000 owner who used OEM suspension and still lapped times faster than 99% of the track guys. Which goes to say, a balanced setup is better than adding parts to the car. I guess what I'm looking for is what is the car's potential direct from the factory without modifying TOO MUCH.
Old 04-21-2012, 11:13 AM   #96
shunya
赤いの雷電
shunya's Avatar
Drives: Nόr
these videos are quite interesting looks like the 86 is more tail happy than the subbie mkay it makes me smile knowing the 86 is tail happy
shunya is offline   Reply With Quote
Old 04-21-2012, 11:28 AM   #97
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I'd say with grippier tires the FR-S will be significantly faster than the BRZ w/ similar tires around tsukuba, reason being that with grippier tires you can expect the FR-S to be much more stable, while the BRZ will start understeering even more than now. I actually believe the FR-S can take slicks w/ some sway bars, shocks/springs and really make good use of them.
TL: DR FR-S should be a much better track car than the BRZ after tire upgrades, (w/ stock suspension). Sway bars may be necessary to reign the body roll in though on both cars.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 04-27-2012, 05:46 PM   #98
yajin
yajin's Avatar
Drives: CBS BRZ(12-), S13(95-97)
Some updates w/ "behind the scene" of these videos are posted on YouTube.
[ame="http://www.youtube.com/watch?v=KvyDuLK4pm0"]CARγƒˆγƒƒγƒ—γ€€η*‘ζ³’γ‚΅γƒΌγ‚*γƒƒγƒˆγƒ†γ‚Ήγƒˆ2012ζ ˜₯ (前編) - YouTube[/ame]
yajin is offline   Reply With Quote
Track Race circuit aloretoc Southeast 3 08-08-2012 11:55 AM
Autoslalom and Time Attack open house this Sunday (April 1st) 7thgear CANADA 0 03-31-2012 10:12 AM
Time for battle: BRZ vs. 86 Poll (w/ comparison photos) GrimmSpeed Scion FR-S / Toyota 86 GT86 General Forum 204 02-26-2012 12:51 AM
FT86c Drift & Time Attack Races in GT5 ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 153 06-25-2011 05:53 PM
FT-86 N2 at Tsukuba OldSkoolToys Off-Topic Lounge [WARNING: NO POLITICS] 11 12-31-2010 12:48 AM
