Old 03-29-2013, 11:15 PM   #71
Calin
VTEC just kicked in, yo!
Calin's Avatar
Drives: World Rally Blue BRZ - 6MT
Originally Posted by ft86me View Post
so simple yet effective. i'm driving my ass to lowes soon and doing this. THANK YOU!!!
I'm also about to drive my ass to Lowes right now. Thanks @JimmyMac !!
Calin is offline   Reply With Quote
Old 03-30-2013, 12:33 AM   #72
Calin
Calin's Avatar
$1.71 at Home Depot!
Old 04-11-2013, 04:51 AM   #73
dacedace
Drives: Ultramarine 86 GTS
I just unpluged mine... So much better, now i need to plug it up.
BTW, the difference is far greater than 3-4db in the frequency range it operates in. Its such an obnoxious sound.
dacedace is offline   Reply With Quote
Old 04-18-2013, 02:54 PM   #74
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Now i need this to plug on my car.
Old 04-19-2013, 09:58 AM   #75
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Does anybody else see to notice some noise still coming from the front right. I still think I can here the engine but it almost sounds like the cat shield vibrating.
Gregg
jdzumwalt is offline   Reply With Quote
Old 05-04-2013, 09:23 AM   #76
Mach5
Did removing the tube decrease the sound level coming from the engine at idle? DI tapping and crickets in particular.
Mach5 is offline   Reply With Quote
Old 05-19-2013, 02:04 AM   #77
GOT FR-S
Drives: 2013 Scion FR-S (Firestorm)
Originally Posted by GrimmSpeed View Post
10. Remove the hose routing back to the cabin. Follow the smaller hose from the noise generator to the frame rail below the strut tower. Disconnect the hose from the 90 degree coupler and cap or otherwise cover the open end.
11. The last remaining step in proper removal of the noise generator is to plug the hole that’s left in the intake tube. You can either wait for the release of the GrimmSpeed Noise Generator Delete plug, or visit your local hardware store for a less elegant, but equally functional solution.
- Matt
I have had that tube non functional for months now, decided to finally remove today. But stupid question..where does the rest of that tube go that is suppose to be capped off? As I managed to pull out that whole piece too...just came out way too easy. Car drives fine, but want to get it capped off or sealed.
Vortech SC. Rev Work Header, Perrin over pipe, Invidia resonated top pipe, Greddy EVO3 exhaust, Perrin Light weight crank pulley, Gofast bits lightweight waterpump & alternator pulleys, Perrin Trans & Shifter mount, MTec Shift springs. Cusco rear diff brace, 1pc Alum Drive Shaft (Drive Shaft Shop), ATC performance clutch & Flywheel, Whiteline Positive traction bushings. Grimspeed hood struts. EcuTek Tune.
GOT FR-S is offline   Reply With Quote
Old 05-22-2013, 05:43 PM   #78
Spencer Strayer
Drifter in Progress
Spencer Strayer's Avatar
Drives: 2013 Ultramarine FR-S, MKV GTi
Yeah my zip tie to that tube broke real easy and the rest of the tube came out. Does it just go into the firewall? Does it really need plugged?
For sale!! Candy White MKV BAGGED! Extreme audio! BBS Super RS's Check it out--> http://www.ft86club.com/forums/showthread.php?t=28938&referrerid=2485
Spencer Strayer is offline   Reply With Quote
Old 05-23-2013, 12:57 PM   #79
Zadkiel
Drives: CBS BRZ Limited 6MT
Plug location on the firewall
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 05-25-2013, 02:44 AM   #80
mid_life_crisis
Drives: FR-S 10 #103 AT
Is it significant? When I blocked the hole from inside the cabin during my test drive, the salesman was astonished by the change.
Edit: Picked up the new car on 9/2. Pulled out of the lot, pulled into the next one, walked around the car, said "excuse me" to the wife, pulled the plug from the glove compartment and put it in the hole in the footwell and pulled back onto the street.
The wife had only heard the car for about a block without the cap and a block later she said, "oh, that is better."
Old 07-05-2013, 06:13 PM   #81
Crystal_White_BRZ
Drives: White BRZ - Limited
I was trying to do this mod. Went to McLendon near by my house, bought the plug and spent 10 minutes looking for this hole on my 10 series FRS. That hole is not exist in the cabin. Can someone else who has 10 series FRS confirm? thanks.
Crystal_White_BRZ is offline   Reply With Quote
Old 07-05-2013, 07:26 PM   #82
White64Goat
First I'd look to see if you even have a sound tube under the hood. Maybe since this is a 'newer' model, it has been deleted? If you have the tube, you have to pull the carpet down on the passenger side floor (near where your toes would be. Should be there if car is still equipped with the tube.
Old 07-05-2013, 09:40 PM   #83
Crystal_White_BRZ
found it, it is on the passenger side. thanks.
Old 11-03-2013, 05:52 PM   #84
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
I found a good rubber plug at Home Depot. It is a 1.5" Quick Cap item # 018578000483 in the plumbing isle. Fits and looks great.
355rockit is offline   Reply With Quote
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
Removing the roof antenna denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2012 11:59 PM
Replacing Axle's in my Elantra suprachica79 Other Vehicles & General Automotive Discussions 3 10-16-2011 10:25 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
