#71 | |
VTEC just kicked in, yo!
Drives: World Rally Blue BRZ - 6MT
#72 |
$1.71 at Home Depot!
#73 |
Drives: Ultramarine 86 GTS
I just unpluged mine... So much better, now i need to plug it up.
BTW, the difference is far greater than 3-4db in the frequency range it operates in. Its such an obnoxious sound. |
#74 |
RedBunny w/ Wing
#75 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Does anybody else see to notice some noise still coming from the front right. I still think I can here the engine but it almost sounds like the cat shield vibrating.
Gregg |
#76 |
Did removing the tube decrease the sound level coming from the engine at idle? DI tapping and crickets in particular.
#77 | |
Drives: 2013 Scion FR-S (Firestorm)
Vortech SC. Rev Work Header, Perrin over pipe, Invidia resonated top pipe, Greddy EVO3 exhaust, Perrin Light weight crank pulley, Gofast bits lightweight waterpump & alternator pulleys, Perrin Trans & Shifter mount, MTec Shift springs. Cusco rear diff brace, 1pc Alum Drive Shaft (Drive Shaft Shop), ATC performance clutch & Flywheel, Whiteline Positive traction bushings. Grimspeed hood struts. EcuTek Tune.
#78 | |
Drifter in Progress
Drives: 2013 Ultramarine FR-S, MKV GTi
For sale!! Candy White MKV BAGGED! Extreme audio! BBS Super RS's Check it out--> http://www.ft86club.com/forums/showthread.php?t=28938&referrerid=2485
#79 | |
Drives: CBS BRZ Limited 6MT
Back in (Crystal) Black.
#80 |
Drives: FR-S 10 #103 AT
Is it significant? When I blocked the hole from inside the cabin during my test drive, the salesman was astonished by the change.
Edit: Picked up the new car on 9/2. Pulled out of the lot, pulled into the next one, walked around the car, said "excuse me" to the wife, pulled the plug from the glove compartment and put it in the hole in the footwell and pulled back onto the street. The wife had only heard the car for about a block without the cap and a block later she said, "oh, that is better." Last edited by mid_life_crisis; 10-01-2013 at 01:40 PM. |
#81 |
Drives: White BRZ - Limited
I was trying to do this mod. Went to McLendon near by my house, bought the plug and spent 10 minutes looking for this hole on my 10 series FRS. That hole is not exist in the cabin. Can someone else who has 10 series FRS confirm? thanks.
#82 |
First I'd look to see if you even have a sound tube under the hood. Maybe since this is a 'newer' model, it has been deleted? If you have the tube, you have to pull the carpet down on the passenger side floor (near where your toes would be. Should be there if car is still equipped with the tube.
#83 |
found it, it is on the passenger side. thanks.
#84 |
Drives: Sci FR-S, Fer F355, Toy Highlander
I found a good rubber plug at Home Depot. It is a 1.5" Quick Cap item # 018578000483 in the plumbing isle. Fits and looks great.
| Removing interior trim dash panels | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 05-30-2012 09:20 AM |
| Removing the roof antenna | denkigrve | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 05-16-2012 11:59 PM |
| Replacing Axle's in my Elantra | suprachica79 | Other Vehicles & General Automotive Discussions | 3 | 10-16-2011 10:25 PM |
| Strange noise | Random_Art | Other Vehicles & General Automotive Discussions | 15 | 06-03-2011 03:31 PM |
