Old 02-03-2014, 12:01 PM   #71
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by Tansey86 View Post
Doesn't an intake manifold need to have different size/volume runners to be optimal for forced induction/NA applications respectively? Or is this going to be a universal fix for both?
That is the goal, we are trying to find the balance between the two.
FullBlown is offline   Reply With Quote
Old 02-03-2014, 12:05 PM   #72
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If these sell like hot cakes, no one would blame you for splitting them apart and making aspiration specific manifolds
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
ChrisD (07-22-2015), TouchMyHonda (02-23-2014)
Old 02-03-2014, 12:21 PM   #73
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by TaroYamada View Post
I guess any serious engineer would have done back 2 back comparison on flow bench from old and new
Agree, but what works on paper and theory, doesn't always work in real life. Its too early to assume all that.
There is a process we go through before we make a cast production product. This is just the fist step.
I know it was a typo (or was it?) but that's exactly what he needs.
It's a pity that sometimes you have to feed the trolls because as a vendor you just can't let their insinuations go unchallenged.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
FullBlown (02-03-2014)
Old 02-03-2014, 12:29 PM   #74
Dipstik-sportech
Dipstik-sportech's Avatar
Yeah I saw his comments and thought they sounded a little condescending
The Frozen North
Old 02-03-2014, 12:38 PM   #75
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We get this all the time, I think we are used to it by now.
Old 02-03-2014, 01:13 PM   #76
mid_life_crisis
The Frozen North
Ding ding ding! It's only the third day and we already have a contender for understatement of the month.
Old 02-03-2014, 01:17 PM   #77
DBW
Motorsports
Drives: 19BRZ PP, 16 M4
If building a full custom manifold why not move the port injectors further up the runner?
Douglas W.
DBW is offline   Reply With Quote
Old 02-03-2014, 02:12 PM   #78
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The problem is the further we move it down, the closer the connector gets to the runner, and there isn't much room down there at all.
We would need to move it at least 12mm down to square up a standard tip injectors.
Old 02-03-2014, 02:17 PM   #79
Dipstik-sportech
I was trying to be nice, I am Canadian it's kinda our thing.
The Frozen North
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
Brody602 (03-07-2014), FreshFRS (02-04-2014)
Old 02-04-2014, 12:58 PM   #80
DBW
Motorsports
You are confused with what I am saying so I made a picture for you. I was saying should move the port injector further up the runner, so you can take full advantage of having a twin injection setup.
Douglas W.
Old 02-04-2014, 01:39 PM   #81
kbye
kbye's Avatar
Drives: 2014 FR-S
You not following what I am saying so I made a picture for you. I was saying should move the port injector further up the runner, so you can take full advantage of having a twin injection setup.
Maybe I am a bit uneducated on the subject but wouldn't it be more beneficial to have the injectors closer to the port? Having it so far up would mess with timing, no? What is the advantage of having it so high up there?
kbye is offline   Reply With Quote
Old 02-04-2014, 02:01 PM   #82
DBW
Motorsports
By moving the port injectors up you get the following benefits.
-Lower Intersect angle since the injectors is now on the radius of the runner.
-Increased charge cooling
-Better atomization of the fuel when using large injectors.
Cons of moving them would be poor idle quality and low load throttle response. However since the FA20 uses a dual injection setup the cons would not matter because you could tune those areas using the Direct injection only.
Doug
Douglas W.
The Following User Says Thank You to DBW For This Useful Post:
Calum (02-04-2014)
Old 02-04-2014, 02:26 PM   #83
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Doug
Low throttle response can be tune, but the DI is turned off below a certain RPM (something like 1800) and above a set RPM (usually set around 7000 rpm).
Luckrider is offline   Reply With Quote
Old 02-04-2014, 04:05 PM   #84
Calum
That Guy
Drives: 2013 asphalt FRS MT
That can be manipulated.
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold cover protpibe Engine, Exhaust, Transmission 16 02-28-2014 06:44 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 12:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
