#71 |
Drives: Scion FRS
#72 | |
Junior
Drives: a car
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | ChrisD (07-22-2015), TouchMyHonda (02-23-2014) |
#73 | ||
Drives: FR-S 10 #103 AT
It's a pity that sometimes you have to feed the trolls because as a vendor you just can't let their insinuations go unchallenged.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | FullBlown (02-03-2014) |
#74 |
Yeah I saw his comments and thought they sounded a little condescending
The Frozen North
#75 |
Drives: Scion FRS
We get this all the time, I think we are used to it by now.
#76 |
Ding ding ding! It's only the third day and we already have a contender for understatement of the month.
#77 |
Motorsports
Drives: 19BRZ PP, 16 M4
If building a full custom manifold why not move the port injectors further up the runner?
Douglas W.
#78 | |
Drives: Scion FRS
We would need to move it at least 12mm down to square up a standard tip injectors. |
#79 | |
The Frozen North
#80 |
Motorsports
You are confused with what I am saying so I made a picture for you. I was saying should move the port injector further up the runner, so you can take full advantage of having a twin injection setup.
Douglas W.
#81 |
Drives: 2014 FR-S
Maybe I am a bit uneducated on the subject but wouldn't it be more beneficial to have the injectors closer to the port? Having it so far up would mess with timing, no? What is the advantage of having it so high up there?
#82 | |
Motorsports
-Lower Intersect angle since the injectors is now on the radius of the runner. -Increased charge cooling -Better atomization of the fuel when using large injectors. Cons of moving them would be poor idle quality and low load throttle response. However since the FA20 uses a dual injection setup the cons would not matter because you could tune those areas using the Direct injection only. Doug
Douglas W.
| The Following User Says Thank You to DBW For This Useful Post: | Calum (02-04-2014) |
#83 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#84 |
That Guy
Drives: 2013 asphalt FRS MT
| Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
| Intake manifold cover | protpibe | Engine, Exhaust, Transmission | 16 | 02-28-2014 06:44 PM |
| Wanted intake manifold | ciro | Want-To-Buy Requests | 0 | 09-27-2013 12:03 PM |
| Aluminium intake manifold? | Hempo | Engine, Exhaust, Transmission | 18 | 06-27-2013 01:19 PM |
| WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
