CSG
Old 12-14-2016, 07:14 PM   #71
Speedy Nick
Drives: Stock
So which is faster in 20min. HPDE session, driven by a seasoned intermediate driver (let's say Buttonwillow 13CW 2:05)?
1) 215/45R17 NT01 or equivalent
OR
2) 225/45R17 RS3
I believe they both heat cycle out and it is getting cold so getting and maintaining heats in the tires are not so much of a problem. I'm thinking of trying 215 but wanted to know if it is even worth the effort...
Speedy Nick is offline   Reply With Quote
Old 01-09-2017, 12:54 AM   #72
BRZ Medic
Drives: 2015 Satin White BRZ
thank you
BRZ Medic is offline   Reply With Quote
Old 01-09-2017, 05:11 PM   #73
kch
Senior Misanthrope
kch's Avatar
OR
2) 225/45R17 RS3
the extra 10mm of the RS3 wouldn't even come close to offsetting the greater performance from the NT01.
The Following 2 Users Say Thank You to kch For This Useful Post:
LOLS2K (01-27-2017), Speedy Nick (05-14-2017)
Old 01-19-2017, 08:01 PM   #74
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
That's a fact.
dradernh is offline   Reply With Quote
Old 01-30-2017, 03:27 AM   #75
maregt
Drives: Subaru BRZ
Nice thread!
Let's say you are constrained between:
- 215/45 AD08R on 17x8
or
- 225/45 AD08R on 17x7.5
Which one would you choose for hpde?
Please, keep in mind that 225/45 on 17x8 isn't possible (not road legal)
Thank you!
maregt is offline   Reply With Quote
Old 01-30-2017, 07:41 AM   #76
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Tire Width?
If you put 225/45/17 on stock wheel, make sure you put some camber in there. & it's better to run tires a little stretched.
Old 01-30-2017, 10:18 AM   #77
Icecreamtruk
Drives: Track preped NA FRS
- 225/45 AD08R on 17x7.5 should be faster
- 215/45 AD08R on 17x8 would feel better
Depending on experience, you might think the car is sliding from the "floating" feel you would get from a tire that is wide on the wheel (the 225s here) and not push it as hard out of fear, in which case 215 would yield better times. If learning and/or having fun is primary objective instead of lap times for bragging rights, then choose 215.
Old 01-30-2017, 02:09 PM   #78
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by maregt View Post
Nice thread!
or
Thank you!
Que? Lolwut?
I'm hoping something is getting lost in translation. What kind of rule would keep you from putting that combo on the car and driving on them?
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 01-30-2017, 02:20 PM   #79
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by TrqlessWonder View Post
Que? Lolwut?
He's in Italy. Some countries are very strict with tire and wheel sizes.
TylerLieberman is offline   Reply With Quote
Old 01-30-2017, 03:46 PM   #80
TrqlessWonder
Drives: 2014 FR-S
I saw that he's from Italy. Hence asking if something got lost in translation. My Italian is far worse than his English. But those particular restrictions seem to fail the logic test.
225/45's are okay on the car
8" wheels are okay on the car
Why would only the pinched/stretched extremes be acceptable? The only thing I can sort of think is if the combo puts the rubber outside the fender. But you'd have that problem with anything on the same 8" wheel. What local law/regulation does the 8"/225 setup actually violate?
But to answer the real question. It's an HPDE. The question getting asked means it's not likely to matter significantly. Bolt on whatever and go have fun.
-Mike
#24 CS/CSR
Old 01-30-2017, 05:16 PM   #81
dradernh
or
I would choose 215/45 on 17X8.
Old 01-30-2017, 08:03 PM   #82
maregt
Drives: Subaru BRZ
Thank you everybody for answering my question...especially TrqlessWonder cause i was waiting for someone to point out the crazyness in my request and his post made me laugh a lot
Sorry if this is OT but i think you deserve an explanation (and a good laugh about italian rules )
In Italy we must stick to stock tire size, but we can change wheels dimensions as long as they fit under the fender and tire is not stretched (this explain the 1st option, my free choice )
IF we want to use a larger tire we need to choose a tire-wheel combination certified by the wheel manufacturer hence the 2nd, quite illogical, option...courtesy of OZ
Back in topic, given your information i think i'd stick with the first option.
Correct me if i'm wrong but to me a floaty sensation means that a taller sidewall and a smaller wheel allow more slip angle if driven correctly (and i like that in 2nd or fast 3rd gear turn), but when i'm going fast (4th-5th gear) i believe what i want is the best feeling possible and i believe this is achieved only with the first opion, am i right?
Old 03-06-2019, 08:44 AM   #83
Speedy Nick
Drives: Stock
Fuji Speedway
The fastest setup at Fuji Speedway is 265/35r18, on 9.5J rims, with 5.1 final-ratio and close-ratio 6th. We use Kumho V70a K61 compounds, and have low-drag GT-wings (e.g. pro-composite). We have no PWR... just headers and intakes.
I run 245/40r17 on 9J rims, with 4.8 final-ratio and stock 6th, to manage costs... for now. It is about 0.5sec to 1.0sec slower compared to the fastest setup.
Once you start to really push, 265/35r18 is the fastest setup even on a high-speed track like Fuji Speedway.
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 01:31 AM
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Track width -max- Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-21-2012 07:37 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
