Old 11-16-2016, 02:08 PM   #71
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Tokay444 View Post
People think "maximum rigidity!!! Because race car!" That's not the case. The stiffer everything gets, the more of a propencity for the car to slide there is.
Again, you're applying suspension principles to chassis design. Two different areas.
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (11-16-2016)
Old 11-16-2016, 02:11 PM   #72
Tokay444
I'm not applying suspension principles to chassis design.
The chassis needs flex. If areas don't flex, other areas break.
Carbon tubs have engineered flex points.
The Following User Says Thank You to Tokay444 For This Useful Post:
new2subaru (11-16-2016)
Old 11-16-2016, 02:13 PM   #73
venturaII
venturaII's Avatar
Done.
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Tcoat (11-16-2016), Ultramaroon (11-16-2016)
Old 11-16-2016, 02:13 PM   #74
strat61caster
strat61caster's Avatar
It's most certainly more than that. I'm willing to bet it's in the tens of thousandths of an inch. The oem bar has no preload adjustment.
Per the previous discussion; less than 0.1mm of deflection.
http://www.ft86club.com/forums/showp...5&postcount=45
0.1 mm = 0.0039"
Thickness of a sheet of paper: 0.005" give or take.
ineedyourdiddly
Tcoat (11-16-2016)
Old 11-16-2016, 02:15 PM   #75
Tokay444
0.1 mm = 0.0039"
Does it go into detail how that summation was derived?
jono_l (11-25-2016)
Old 11-16-2016, 02:15 PM   #76
strat61caster
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
go_a_way1 (11-16-2016), Tcoat (11-16-2016)
Old 11-16-2016, 02:18 PM   #77
Tokay444
It's fine. I'll mount an indicator on the fire wall and go for a drive and measure shock tower deflection. If it's less than .005", I'll be very surprised.
Old 11-16-2016, 02:20 PM   #78
strat61caster
Fuck, statements like this are how I get suckered into two hour meetings about this shit. Looking forward to the results.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
go_a_way1 (11-16-2016), JazzleSAURUS (11-16-2016), Tcoat (11-16-2016)
Old 11-16-2016, 02:22 PM   #79
churchx
churchx's Avatar
Drives: 2014 GT86
Tokay444: You have bushings & suspension for parts where movement/flex is needed "for things not to break", "for car to be more comfortable" and to keep grip un uneven road surfaces. In chassis however extra flex in most cases just rob you of control. Yes, it also may impact grip, but it's much better to get that grip with appropriate suspension changes, then with reducing chassis rigidity. There is reason why manufacturers always boast about strengthening chassis vs older generations as an achievement in PR materials whenever they stiffen up chassis with slight redesign or usage of stronger steel.
Old 11-16-2016, 02:23 PM   #80
Tokay444
Two objects that are tied together mind you.
Old 11-16-2016, 02:24 PM   #81
gramicci101
Off Topic
I don't get paid enough to argue about things that move less than the thickness of a sheet of paper at work, much less here. I'm out.
Oh yeah? Well I say that you DO get paid enough to argue about things that move less than the thickness of a sheet of paper! What do you say to that, huh?!
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
EAGLE5 (11-16-2016), strat61caster (11-16-2016), Tcoat (11-16-2016)
Old 11-16-2016, 02:26 PM   #82
Tokay444
The reason they release articles like that for PR, is because people who know nothing about engineering buy into it.
Also, strength doesn't always mean rigidity.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
Cole (11-16-2016), strat61caster (11-16-2016)
Old 11-16-2016, 02:42 PM   #83
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Haha good idea. Next time you are taking a corner hard push your finger in between the dash and door, you will feel it flex and squish your finger, with TRD door stabilizers this is reduced significantly
Door flex is not the same as chassis flex. Doors are only a part of the chain. So check that tire. See if opening the doors makes it hit the ground. If it does then we know there's a lot of flex without the doors. I really wouldn't expect a big difference in our stiff little cars. Not sure what the Nm/deg is, but I imagine it's well north of 20k.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 11-16-2016, 02:44 PM   #84
EAGLE5
Dismember
EAGLE5's Avatar
My understanding is that stiffness/rigidity is how little it bends/deflects for a given force, and strength is how much force it can take before breaking. We're talking about rigidity here.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Cole (11-16-2016), Tokay444 (11-16-2016)
Prothane Motion Control Looking for Test Vehicle itsibarra Southern California 2 05-22-2015 01:13 PM
Motion Control Suspension coilovers xwd Tracking / Autocross / HPDE / Drifting 27 02-21-2015 11:24 PM
is there a shorter endlink out there? mcs motion control damper toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2014 08:28 PM
motion control suspension(mcs) spring length toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-21-2014 12:42 PM
Motion Control Suspension andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-30-2014 11:55 PM
