Old 11-28-2014, 12:25 AM   #813
steve99
Originally Posted by sirsol66 View Post
That was my thought too, being an engineer I tend to overthink things (my GF reminds me of that everyday lol) so I'll just keep an eye on it.
Car is going away for winter anyways after this weekend when the salt starts flying, so I'll log it in the spring.
look at your long term fuel trims in that area and also iam and knock flkc and fbkc knock correction.
it might be dodgy fuel as well
Old 11-28-2014, 07:42 AM   #814
sirsol66
Drives: 2013 FRS- Hot Lava
Will do, but the odd thing is that it only did it those two times and never again, making me think it has something to do with the car warming up or such. Plus it had never been driven in that cold of weather with the tune. Ill try to log it.
sirsol66 is offline   Reply With Quote
Old 11-28-2014, 08:57 AM   #815
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Colder temps can make bad fuel show if your fuel is 10% ethanol. At warmer temps the fuel absorbs any water and allows you to burn it off. When fuel is much colder some water can separate out and cause problems. Add a bottle of fuel dryer and that should fix things.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 11-29-2014, 09:27 PM   #816
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Arrow
Is it pointless to tune with the Open Flash Tablet, if I am eventually planning to get the HKS supercharger kit?
Chad86 is offline   Reply With Quote
Old 11-29-2014, 10:16 PM   #817
Apoc
Apoc's Avatar
You can use it until you decide on a different tuning solution. Once the OFT is unmarried you can sell it very easily
“The World is Flat”
[||•]=(86)=[•||]
Old 11-30-2014, 06:59 PM   #818
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
So I've got everything on the way now for this car and was curious as to what would be the best route for a map to run with my car. I'll be pairing off Tomei EL headers with the new Grimspeed intake and I know there's a specific stage 1 for the intake, what would be the best way to go given that I'm also running headers?
Obviously stage 2 but is it possible or likely that the map can be optimized still for that intake on a stage 2 map?
TylerLieberman is offline   Reply With Quote
Old 11-30-2014, 08:57 PM   #819
steve99
copy the maf scale out of the grimspeed intake stage 1 tune to the stage 2 tune.
Then check you afr LTFT and for knock to see all is ok.
Old 11-30-2014, 09:04 PM   #820
Apoc
Apoc's Avatar
@Shiv@Openflash Where is the grimspeed tune available? I have sent emails and PMs to Shiv but haven't heard a word.
“The World is Flat”
[||•]=(86)=[•||]
Old 12-01-2014, 07:29 PM   #821
underpowered
Drives: brz
Hopefully this map will come out soon. I am waiting to do the power blocks until this map is out. I figure between this map and the crawford power blocks map I should be able to make a map that will work with both.
underpowered is offline   Reply With Quote
Old 12-02-2014, 02:23 PM   #822
pl1ght
Drives: 2015 Alfa Romeo 4C
Just got my OFT in! Assuming that my CAL ID ends in B00C, so for stage 1 i would use the 93 oct, stg1 b00c.bin correct?
pl1ght is offline   Reply With Quote
Old 12-02-2014, 02:40 PM   #823
steve99
yes as long as your going to run 93 fuel
Old 12-02-2014, 07:52 PM   #824
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
There's separate tunes for 91 and 93 oct. Pick whichever gas you will be using. As Steve said
Old 12-02-2014, 08:32 PM   #825
pl1ght
Yeah 93, sorry, you never know tho right? Thanks for the info. Amazed how how much it affects that torque dip. can't wait to get my OFT UELs in now!
Old 12-21-2014, 02:47 PM   #826
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Okay noob question, but when it states to turn the key to ignition does that mean to start the car up as well?
MokSpeed is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
