Old 07-09-2015, 06:26 AM   #57
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
In my experience the easiest way to do it is to use the ae64.com harnesses. They provide a 16 pin connector for camera and 6V power as well as making an accessory 12V harness that plugs into an unused plug behind the radio ("Option harness"). With those connectors you just plug the camera video to the 16 pin harness, plug power and ground to the option harness, plug the reverse wire into the big harness in the footwell and the other end to the 28 pin harness on the radio and run your wires (in my opinion running the wires was the hardest part).
I used bullet connectors for everything so I didn't permanently modify any wiring (other than the splice for the reverse wire). I also extended all the wires in the main camera harness to be the same length as the power and ground were much shorter than the video signal. Snaked them up the trough under the panels on the driver's side, through the rear seat and around the trunk lid to the cam. Really wasn't that big a deal.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-09-2015, 05:29 PM   #58
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
Using the option harness means your camera is on all the time when the accessory is on. Probably not a big deal but mentioning that in case it matters to some.
'14 BRZ CBS
>>Pretty Stock
a_dee is offline   Reply With Quote
Old 07-24-2015, 09:45 PM   #59
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
Originally Posted by SVXdc View Post
I'd be interested to see good pictures of their harness. I'm curious where they're getting power for the camera.
The harness they're currently showing on that page can't be the actual one for BRZ. The harness shown (link) has 10-pin connectors, and nothing that connects to a camera. The BRZ HU's camera sockets have 16 and 4 pins. Their harness looks like something for other Toyota models. And the picture at the bottom of the page just shows the camera and its long video cable. No car-specific harness.
This is the rear view camera set up i bought and will be installing this tonight.
Hopefully it goes smooth.
mixedjuice is offline   Reply With Quote
Old 07-24-2015, 09:46 PM   #60
mixedjuice
Originally Posted by 2k15BRZ View Post
This is the route I went. Haven't installed it yet, but it's plug & play out of the box. http://www.emeraldintegrations.com/c...ra-system.html
I hope it worked perfect for you. @2k15BRZ
I will be installing mine today!
Old 07-31-2015, 05:42 PM   #61
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
any updates? @mixedjuice
sounds like @czechm8 find a easier way to do it but can you explain better...? Cuz i really wanna do this but I have zero knowledge on wires & stuff...
Old 07-31-2015, 06:20 PM   #62
mixedjuice
@chaoskaze
yeah i finished my project. the lines turned out pretty good. of course not factory lined up perfectly.
but very useful and still very flush/clean installed.
Old 07-31-2015, 06:37 PM   #63
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
Originally Posted by mixedjuice View Post
@chaoskaze
Post a pic of the cam and actual output of the head unit please :o
'14 BRZ CBS
>>Pretty Stock
Old 07-31-2015, 06:53 PM   #64
mixedjuice
coming up! just gotta get this to work on my mobile phone
Old 07-31-2015, 07:17 PM   #65
mixedjuice
Here are the 3 pieces that plug and play together.
1. 16 pin harness that plugs into the back of the headunit.
2. male to male video cable with power wires on each end
3. female video input cable attached to a camera with power and ground wires.
remove headunit
unplug factory 16 pin harness
plug in new 16 pin harness
plug original 16 pin harness to the extension of the new 16 pin harness
plug yellow male video input into female input
tap red wire to a 6V+ wire on the factory head unit. (i used the ACC/yellow cable)
run the wires to the back of the car, under all the carpet and trim
plug the other end male video input to the camera output video
grimp the 2 red power cords together
ground the black wire
drill a whole to the back fender where the camera will go.
screw in and adjust
finished
upon starting the car, place in REVERSE, camera should power on once in gear
Old 07-31-2015, 07:53 PM   #66
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
It's interesting on the camera vertical range, can you see directly behind you? I had to hack mine to be able to see directly behind me. But I do get a bigger picture overall as I no longer have 1/3 of my screen showing the bumper.
The camera actually looks very similar if not externally identical to mine which I got off eBay.
'14 BRZ CBS
>>Pretty Stock
Old 07-31-2015, 08:19 PM   #67
mixedjuice
@a_dee
i can see directly behind me, but with an angle. how the camera is angled coming from a straight install it does show the portion of the bumper.
there is a white cord the is the angle/mirror cord that i kept on. (i didnt want to cut it)
but i did cut the green cord that had parking lines in it.
Old 07-31-2015, 08:20 PM   #68
mixedjuice
What kind of hack? I am interested to see if this can help my current angle.
Old 07-31-2015, 08:30 PM   #69
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
I made a shim to change the angle out of rubber (jeweler's bench block), pics attached of before and after.
'14 BRZ CBS
>>Pretty Stock
Old 08-01-2015, 12:06 AM   #70
mixedjuice
Looks like i need to fabricate a little more!
awesome solution man @a_dee
how is you build doing? im looking into buying a used (4k miles) perrin performance exhaust. But still cant get myself to buy it coz i am looking for rims and tires more
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 09:53 AM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 12:25 PM
be spoke with rear view camera harness fs xpicer Audio/Visual, Electronics, Infotainment, NAV 1 11-25-2012 02:35 PM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
