Old 08-14-2012, 01:41 PM   #1
Foobar
SLO NO MO
Foobar's Avatar
Stock Rear View Camera for Fujitsu Ten?
EDIT: any NTSC Camera will work with our headunit - pins 8 and 16 on the 16 pin harness take the video +/- signal. So long as the camera has power when the head unit starts up, it'll recognize it.
Old 08-14-2012, 03:16 PM   #2
OrbitalEllipses
Drives: Attitude
Old 08-14-2012, 03:37 PM   #3
Foobar
SLO NO MO
Foobar's Avatar
I actually did search. Only thread I found was someone trying to sell their own custom deal and it referred to a vendor post that no longer exists and a couple of the comments saying how unreasonably priced it was. But thanks, I'll try a few more permutations on the search and see what I can find out.
Old 08-14-2012, 03:47 PM   #4
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
I've also been trying to find this. The connectors there but there's only one wire coming out of the harness (gray for the e-brake wire). I've been contemplating adding the correct pins the harness - if you find anything please post back.
Thanks
rmjjensen is offline   Reply With Quote
Old 08-14-2012, 04:08 PM   #5
sparks
sparks's Avatar
As a Subaru Parts Manger and retired Navy Electronics Technician, I'll add this:
The rear camera is available for the 2012/2013 Forester and Impreza.
The Forester does have a seperate rear cord for the camera that I can order.
There are several patch connectors available for the Forester and Impreza that are used when the nav is installed (I have all 3 on order).
The camera connection comes in the radio on Connector B a 16 pin plug, and the plug for the BRZ only has 1 wire (hand brake).
The rear camera kit for the Forester lists for $160.00
The hard parts:
Pins for the existing radio plug or get lucky with one of the patch cables.
Buy and mount the camera
Running 4 wires
Determine what tells the radio to switch to back up mode, or will it be automatic when it see's the camera is connected.
I too saw the vendor thread, I also think the pricing is WAY to high for a camera 2 plugs, and a legnth of 4 wires.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 08-14-2012, 04:37 PM   #6
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
The hard parts:
Running 4 wires
Please keep us updated!! Thank you very much!
Lee358 is offline   Reply With Quote
Old 08-15-2012, 06:44 PM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
The hard parts:
Running 4 wires
Can't wait to see your results!
Old 08-17-2012, 11:06 AM   #8
Foobar
SLO NO MO
Foobar's Avatar
The hard parts:
Running 4 wires
Sparks, are you experimenting with this? I'll probably get the parts and start playing around with this as well, but if you've already made some headway, I'd hate to reinvent the wheel (and possibly make the same mistakes).
Old 08-17-2012, 02:17 PM   #9
sparks
sparks's Avatar
Yes the first patch cable arrived today and it's an antenna cable, no luck. The other two will be here Monday.
Old 08-17-2012, 04:46 PM   #10
xwd
I did receive an email from SVXdc who makes the cables for the Imprezas/Foresters. He said he could supply a harness with the RCA plug and the pins to install into the factory 16-pin connector. Basically just put the pins in the right place on the connector, pretty easy. I don't know if that comes with the power cable to power the OEM camera, I'm assuming it does. I may not end up using the OEM camera to begin with just to make sure everything works okay.
He has made these for the Fujitsu Ten units in the 2012 Forester/Impreza.
Old 08-20-2012, 01:31 PM   #11
sparks
sparks's Avatar
The remainng cables came in, both are antenna related.
Looks like I need to contact SVXdc for some contacts
Old 08-20-2012, 02:13 PM   #12
sparks
sparks's Avatar
So it looks to be get this - http://www.ebay.com/itm/US-Store-Wid...item416708d70c
Then talk to SVXdc about an rca to two pins for the 16 pin plug.
Old 08-20-2012, 02:31 PM   #13
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Thanks for doing the research guys. A link to his website.
http://ae64.com/
illmatic is offline   Reply With Quote
Old 08-20-2012, 03:54 PM   #14
sparks
sparks's Avatar
One way or another I am going to make this work
After a little more research, the head unit puts out 6V to turn on the camera, not needed.
The head unit does get a reverse input.
The back up lights can be tapped to power the 12V camera.
All we need now is pins to RCA and a DIY
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
Zoom Engineering Rear View Mirrors Kami Speed Interior Parts (Incl. Lighting) 13 07-17-2012 02:18 PM
Taking rear view mirror off ? JB1 Cosmetic Modification (Interior/Exterior/Lighting) 7 06-21-2012 09:53 AM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 05:10 PM
