#57 |
Drives: 2013 Scion FRS
Yea, looks like 30 peak gains on 91, 40+ on e85.
| The Following User Says Thank You to Hades For This Useful Post: | NAEightySix (03-04-2018) |
#58 |
Drives: brz 2017 hksv2
| The Following User Says Thank You to tomm.brz For This Useful Post: | Apex No.525300887039 (03-04-2018) |
#60 |
The combination of the single best long tube EL header on the market for the FA20, combined with the most experienced FA20 tuner in the world, can make for some impressive results.
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | FunnyGopher (03-04-2018), Hades (03-04-2018), NAEightySix (03-05-2018), RJasonKlein (03-04-2018), ThatAsianBradah (03-06-2018) |
#61 |
Drives: 2016 Subaru BRZ
| The Following User Says Thank You to Trueweltall For This Useful Post: | NAEightySix (03-05-2018) |
#62 |
#63 | |
Drives: 2013 WRB BRZ 6MT
I've seen multiple independent dynos now report closer to 20-30whp peak gains with this exact same setup but I don't say that to discount what the Ace header and Delicious tune can do because there is more to it than peak power. This setup offers the strongest area under curve available of any setup on the market and that is really where most of your time is spent accelerating. This is a little more inline with what to expect if your car is running well to begin with: |
| The Following 2 Users Say Thank You to Lynxis For This Useful Post: | NAEightySix (03-05-2018), tomm.brz (03-06-2018) |
#64 | |
If the 2017 really made 180whp on a "standard" dyno, it would pull on a K20 powered civic... and it doesnt. |
#65 |
Drives: '15 BRZ RA
The 2017 stock cars fix the tuning issue and don't target 10.2 afr at WOT. However, this behavior stays just for a single pull and then they start adding fuel and have a rich afr again. This causes to lose power. It was reported sometime ago. So, it is easy to compare stock and with a header and tune and have a variance between 20hp and 30hp even on same dyno.
Here is the post: http://www.ft86club.com/forums/showp...28&postcount=1 Last edited by nikitopo; 03-06-2018 at 06:16 AM. Reason: Included the post |
| jdl header / tune questions | dtrop | Engine, Exhaust, Transmission | 13 | 03-31-2016 04:40 PM |
| Header Gasket Questions | gepeyo | Northern California | 11 | 02-02-2015 11:51 PM |
| EL header questions | newports | Engine, Exhaust, Transmission | 2 | 03-29-2014 02:41 AM |
| Intake, Header, Exhaust questions | KillionsFRS | Engine, Exhaust, Transmission | 8 | 09-05-2013 11:12 PM |
| header tech questions and opinions | ft86me | Engine, Exhaust, Transmission | 7 | 04-01-2013 04:40 PM |
