Northern California NorCal
Old 01-24-2015, 09:55 PM   #1
gepeyo
Opal86
gepeyo's Avatar
Drives: 2013 10 Series #Opal86
Header Gasket Questions
So I am buying my friends OFT and Borla Unequal Headers and was wondering about the gaskets. I was informed that i should replace them when i change my headers. I ways also told that i shouldnt use grimmspeed gaskets because of possible leaking? anyone have experience on headers or opinions on grimmspeed headers. I rather ask norcal86 instead of everyone as a whole.
Thanks.
gepeyo is offline   Reply With Quote
Old 01-24-2015, 10:37 PM   #2
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
I've used OEM header gaskets and grimmspeed gaskets on a JDL header, I've noticed no difference in either one. Grimmspeed is thicker and seems higher quality.
Just make sure you re-tighten the 6 bolts after you run them through a heat cycle cause they will leak. I torqued mine at 35 ft/lb
BAMF86 is offline   Reply With Quote
Old 01-24-2015, 10:44 PM   #3
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Definitely replace them when you install the new headers. Don't know about Grimm speed gaskets, but I've had good luck with OEM, just make sure they are torqued down to spec and you won't have any leaks
Old 01-25-2015, 01:05 AM   #4
gepeyo
Opal86
gepeyo's Avatar
The thing is, ive contacted a dealership for OEM Brackets and its going to be a long while until I can get oem brackets. Also i am not experience in installing the headers, so I am taking it to a high reputation shop in my local area to get them in, so i want to get gaskets asap.
Old 01-25-2015, 01:28 AM   #5
BRZY
BRZY's Avatar
Drives: World Rally Blue BRZ
If you're going to have a shop do the work, have them get the gaskets for you. They definitely have better sources for gaskets at a better price in which they might pass down to you. Gaskets are pricey. IIRC, list price was $15~20 a pop.
BRZY is offline   Reply With Quote
Old 01-25-2015, 01:40 AM   #6
gepeyo
Opal86
gepeyo's Avatar
My guy told me its best to contact my dealership, im just unsure if im willing to wait a month for the pair of gaskets, do you also know if i need to replace the other gasket too? or just the 2 header gaskets?
Old 01-25-2015, 02:48 AM   #7
BigFatFlip
BigFatFlip's Avatar
Got my parts here: http://subaruonlineparts.com/
Not sure how long it took to get em, but definitely not a month.
Old 01-25-2015, 04:10 PM   #8
BRZY
BRZY's Avatar
i have a pair unused oem header gaskets. lmk im be in the city on mon~thurs
Old 01-25-2015, 04:18 PM   #9
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
A month is too long, my dealership was able to get it shipped to them the next day, and it was about $20 for both.
By running them through heat cycle, do you mean just driving it hard and then re-torquing them?
Old 01-25-2015, 05:41 PM   #10
BAMF86
much slow
BAMF86's Avatar
Yes, just do a bunch of pulls or drive the piss out of it. Mine we're leaking pretty badly after one HPDE
Old 01-26-2015, 02:29 AM   #11
gepeyo
Opal86
gepeyo's Avatar
Drop by the SF/Bay meet on tuesday? Ill most def be there and down to buy those gaskets off you :]
Old 02-02-2015, 10:51 PM   #12
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
When I did it with Grimmspeed gaskets, it leaked like a seive. Sounded like a chainsaw under the hood, and smelled like the 60s. With OEM gaskets, no issue.
Literally every other gasket in the exhaust system had a small leak, as I found later via smoke test. I recommend replacing every seal you touch, and ordering an extra one or two of the donwstream gaskets: I had to stack a couple in order to completely stop the leakage.
Gosh, it's almost like components from different manufacturers shouldn't go together
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Need to replace FP/MP gasket when installing header? 1Cor10:23 Engine, Exhaust, Transmission 16 04-24-2014 04:09 PM
EL header questions newports Engine, Exhaust, Transmission 2 03-29-2014 01:41 AM
Intake, Header, Exhaust questions KillionsFRS Engine, Exhaust, Transmission 8 09-05-2013 10:12 PM
header tech questions and opinions ft86me Engine, Exhaust, Transmission 7 04-01-2013 03:40 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
