Old 03-04-2018, 04:45 PM   #57
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Yea, looks like 30 peak gains on 91, 40+ on e85.
Hades is offline   Reply With Quote
The Following User Says Thank You to Hades For This Useful Post:
NAEightySix (03-04-2018)
Old 03-04-2018, 05:06 PM   #58
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by Apex No.525300887039 View Post
Red is E85
Blue is 91 Octane (~95RON?)
header only IIRC
Header AND tune i hope.. well ok 30hp is more credible
Apex No.525300887039 (03-04-2018)
Old 03-04-2018, 05:56 PM   #59
Drives: 2016 Scion FRS
Tune was to be assumed lol, I meant header only in terms of hardware
Apex No.525300887039 is offline   Reply With Quote
The Following User Says Thank You to Apex No.525300887039 For This Useful Post:
CSG Mike (03-04-2018)
Old 03-04-2018, 09:53 PM   #60
CSG Mike
CSG Mike's Avatar
i'm surely missing something, but how is 42hp gain even possible with just header+ tune
i have UEL header + full skat + tune from Fensport and I don't even reach a 20hp gain with 100Ron fuel... and you get 42hp with just header and tune and normal fuel?
The combination of the single best long tube EL header on the market for the FA20, combined with the most experienced FA20 tuner in the world, can make for some impressive results.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
FunnyGopher (03-04-2018), Hades (03-04-2018), NAEightySix (03-05-2018), RJasonKlein (03-04-2018), ThatAsianBradah (03-06-2018)
Old 03-05-2018, 07:57 AM   #61
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
James Martin tuned that car? Interesting.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Old 03-05-2018, 06:58 PM   #62
CSG Mike
CSG Mike's Avatar
I didn't know he'd been full time tuning FA20's for 6 years!
Old 03-05-2018, 07:46 PM   #63
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
My suspicion in cases like these is that the baseline had unreported issues that were robbing power, probably a clogged cat or some minor tuning issue. I've seen multiple stock 2017 baseline dynos at ~180whp so a baseline of 165 implies to me there was probably something wrong. Change to catless and a new tune will iron out these issues obviously so gains are inflated.
I've seen multiple independent dynos now report closer to 20-30whp peak gains with this exact same setup but I don't say that to discount what the Ace header and Delicious tune can do because there is more to it than peak power. This setup offers the strongest area under curve available of any setup on the market and that is really where most of your time is spent accelerating.
This is a little more inline with what to expect if your car is running well to begin with:
Lynxis is offline   Reply With Quote
The Following 2 Users Say Thank You to Lynxis For This Useful Post:
NAEightySix (03-05-2018), tomm.brz (03-06-2018)
Old 03-06-2018, 01:42 AM   #64
CSG Mike
CSG Mike's Avatar
Different dynos read differently. That's why it's so important to do ALL the measurements on the same dyno.
If the 2017 really made 180whp on a "standard" dyno, it would pull on a K20 powered civic... and it doesnt.
Old 03-06-2018, 02:24 AM   #65
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The 2017 stock cars fix the tuning issue and don't target 10.2 afr at WOT. However, this behavior stays just for a single pull and then they start adding fuel and have a rich afr again. This causes to lose power. It was reported sometime ago. So, it is easy to compare stock and with a header and tune and have a variance between 20hp and 30hp even on same dyno.
Here is the post: http://www.ft86club.com/forums/showp...28&postcount=1
jdl header / tune questions dtrop Engine, Exhaust, Transmission 13 03-31-2016 04:40 PM
Header Gasket Questions gepeyo Northern California 11 02-02-2015 11:51 PM
EL header questions newports Engine, Exhaust, Transmission 2 03-29-2014 02:41 AM
Intake, Header, Exhaust questions KillionsFRS Engine, Exhaust, Transmission 8 09-05-2013 11:12 PM
header tech questions and opinions ft86me Engine, Exhaust, Transmission 7 04-01-2013 04:40 PM
