Old 03-31-2013, 07:02 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
header tech questions and opinions
I saw this on ft86speedfactory
http://ft86speedfactory.com/hks-equa...lyzer-789.html
what do you guys think? Only reason I am looking at the catalyzer one is because my test pipe is catless. I could always go with a catted test pipe by nameless but that's an extra 600.
Also, I have seen things on the forums about the length of some tubes being longer and what not and it would be better for some pipes to be longer etc. Generally nameless having longer pipes? I'm not sure if I am totally messing things up here, but can someone explain this for me? I do understand the difference between el and uel, but something about pipes being longer.
thanks guys!
ft86me is offline   Reply With Quote
Old 04-01-2013, 10:13 AM   #2
Mike86
Drives: Scion frs
If im not mistaken i think some headers replace the overpipe and some dont so that would probably be the difference in lenght!!
Mike86 is offline   Reply With Quote
Old 04-01-2013, 01:45 PM   #3
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
thanks guys!
You can be long tube vs short tube, and Equal length vs Un Equal Length. Each has their benefits and drawbacks in the grand scheme of things.
The P&L, Fa20club, and Nameless are all long tube headers. It allows for lower rpm exhaust flow, and an increase in low end torque which will help with the elimination of the torque dip in our cars, the drawback is usually always the sound.
EL vs UEL allows for the gas to clear from different cylinders at different times.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
Craig (04-01-2013), ft86me (04-01-2013)
Old 04-01-2013, 02:38 PM   #4
ft86me
ft86me's Avatar
Drives: 2013 FRS
What do you mean by sound?
Old 04-01-2013, 02:56 PM   #5
Hawaiian
That guy
Hawaiian's Avatar
[QUOTE=ft86me;833589]What do you mean by sound?[/QUOT
they are generally louder, sometimes a little raspy. You need to do more exhaust work to make them sound better. especially when you move from a UEL to an EL header.
Ultramarine mt FR-S
P&L stage 1 turbo
The Following User Says Thank You to Hawaiian For This Useful Post:
ft86me (04-01-2013)
Old 04-01-2013, 03:15 PM   #6
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
[quote=Hawaiian;833644]
I can second this. PPE EL Header with Berk catted front pipe and stock catback rasps.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
ft86me (04-01-2013)
Old 04-01-2013, 03:15 PM   #7
ft86me
ft86me's Avatar
Drives: 2013 FRS
I have the ark header back. Hmm I wonder
Old 04-01-2013, 03:40 PM   #8
FR-S Matt
I'll be doing a Resonated Downpipe with a beefy resonated midpipe for a full 3" system with the Nameless header. Dual resonators with their 3" offset Axleback should make it reasonable.
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
TEIN S-TECH AND H-TECH FOR 2013 FRS & BRZ IN STOCK!! genometuning Brakes, Suspension, Chassis 7 10-13-2013 09:49 PM
opinions please.... sillyxmico BRZ First-Gen (2012+) — General Topics 15 01-18-2013 07:21 PM
