Old 03-03-2018, 02:25 PM   #43
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Originally Posted by nikitopo View Post
Who said I am comparing with my car? I just don't like someone to say that you can get a +40-50 hp gain just with a header and a tune. It is unrealistic. If you go with E85, then yes you are much closer. However, if you want to do it right then you the need a flex fuel kit and be lucky enough to find always a gas station.
I don't think he said you gain 40-50 hp with a header+tune, he only showed a graph.
But if we assume the graph is correct, he actually gained 30hp@peak power (without E85), and almost 40hp at 4500rpm (still without e85).
Like Kodename47 I am also interested to know why not keep the 2017 FD?
nico_rsx is offline   Reply With Quote
Old 03-03-2018, 03:21 PM   #44
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes peak power is +30hp (without E85), but it is not enough to pull a s2k. You need more power and not 1hp,2hp or even 5hp. With such a small difference it will take forever to pass the other car. You don't have too much length on a track. If both cars were at 4500rpm, then yes the BRZ would have an advantage. The S2K is pretty weak in these rpms. The issue is that if you are pulling hard and you are at 45000rpm, then you are doing something wrong (wrong gear or too long final drive ratio for the specific track). So, I find it unlikely that they were pulling from that low.
Old 03-04-2018, 01:21 AM   #45
Doozer
Doozer's Avatar
Drives: gt86...among others
Opinion only
S2K's are faster in the corners and in a straight line
86 chassis is more stable and much better under braking
no idea the numbers S2K's are putting out
Success from beating S2K's only comes from patience. (again, opinion only)
Once in front, the 86 can pull away using braking techniques to limit the S2K's offensive weapons
This particular pass was only because S2K driver missed a shift.
S2K is Motec CR2000 with "red head" built engine. FD unknown. Tires: Yokohama A005
86 is Delicious E85 with Anaconda 42.9 header and 4.8FD. No aero and stock motor. Tires: Michelin S8C
[ame="https://www.youtube.com/watch?v=yxm2QmpoWyo&t=1s"]BRZ GT86 FRS v S2000 - YouTube[/ame]
racing gods live deep in corners
Doozer is offline   Reply With Quote
Old 03-04-2018, 01:47 AM   #46
CSG Mike
CSG Mike's Avatar
Originally Posted by Kodename47 View Post
So you put the older FD in the newer car?
sure did!
Old 03-04-2018, 01:47 AM   #47
CSG Mike
CSG Mike's Avatar
Lol, you have a tendency to over exaggerate things. We were not discussing here about E85, but just changing the header and the tune. You cannot pull a S2k in straight line with these two changes.
I own both cars, and this is a roll race I've done many, many times with non-believers. Result is conclusive.
Old 03-04-2018, 01:50 AM   #48
CSG Mike
CSG Mike's Avatar
Lets do some ricer bench racing.
165.7whp = 205 crank hp. That extrapolates to 195.3whp = 241.6 crank hp. The S2000 is 237 crank hp. Not only that, the F22C's peak power is at redline, so you only get to ride one side of the curve. With the FA20 + Ace, you get to ride both sides of the curve, resulting in a larger AUC.
Even the math checks out, quite conclusively.
Old 03-04-2018, 02:01 AM   #49
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
Originally Posted by Doozer View Post
Opinion only
Great stuff, it seemed pretty close most of the time, you seem like a great driver.
Would aero mods have helped you close the gap more in the corners?
Also, why the Anaconda over the 350 or CS400?
NAEightySix is offline   Reply With Quote
Old 03-04-2018, 02:06 AM   #50
NAEightySix
Thanks to everyone; it’s nice to see different people’s opinion.
Hopefully, this’ll help me decide on something I’ll be happy with... my car is nothing more than a daily driver as of right now that I drive spiritedly whenever possible, although I’d like to take it to the local track one day and see how it fares against other cars.
Both my brothers have AP2s and it seems that they’re always mocking the potential the 86 has lmao
Old 03-04-2018, 05:51 AM   #51
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I am sorry if I insist on this, but you cannot really calculate the crank hp of the updated car with extrapolation. Losses on the wheel are not the same with different power levels.
Here is a video of 80-180km/h (50-112mph) of a 86 with Ace 350 header & tune AND a 4.67 final drive ratio. The other video is of a stock S2k AP1.
I measured both results and approximately we have:
86: 13.0 sec
s2k: 12.8 sec
You might say that they are almost identical, but not that the 86 will pull the s2k in straight line. And don't forget that the particular 86 has a changed final drive ratio which helps a lot in the result ...
Old 03-04-2018, 09:51 AM   #52
CSG Mike
CSG Mike's Avatar
86: 13.0 sec
s2k: 12.8 sec
Okay cool. So lets rev that car to redline, instead of 7300, and try again. I suspect you'll have a vastly different result.
Alternatively, a car with a stock final drive will ALSO have an even faster result, due to 1 less shift (do the math for gearing).
Old 03-04-2018, 11:39 AM   #53
Hades
Hades's Avatar
Drives: 2013 Scion FRS
I don't see where the debate is. 86 + Ace makes more power than a *stock* s2k everywhere. I doubt it could pull on an s2k with IHE but would love to be proven wrong.
Hades is offline   Reply With Quote
Old 03-04-2018, 01:46 PM   #54
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What's funny is why are we comparing different cars at this point? I think the general question you see on the forum is what is the best header? Shouldn't this be about comparing the ACE to other headers on the 86 platform?
I'd advise anyone interested in purchasing to throw the numbers out of the window and just look at the damn curves.
Old 03-04-2018, 03:21 PM   #55
tomm.brz
Drives: brz 2017 hksv2
I don't know how many times you've seen this, but have it again!
i'm surely missing something, but how is 42hp gain even possible with just header+ tune
i have UEL header + full skat + tune from Fensport and I don't even reach a 20hp gain with 100Ron fuel... and you get 42hp with just header and tune and normal fuel?
Old 03-04-2018, 03:43 PM   #56
Apex No.525300887039
Drives: 2016 Scion FRS
Red is E85
Blue is 91 Octane (~95RON?)
header only IIRC
Apex No.525300887039 is offline   Reply With Quote
jdl header / tune questions dtrop Engine, Exhaust, Transmission 13 03-31-2016 03:40 PM
Header Gasket Questions gepeyo Northern California 11 02-02-2015 10:51 PM
EL header questions newports Engine, Exhaust, Transmission 2 03-29-2014 01:41 AM
Intake, Header, Exhaust questions KillionsFRS Engine, Exhaust, Transmission 8 09-05-2013 10:12 PM
header tech questions and opinions ft86me Engine, Exhaust, Transmission 7 04-01-2013 03:40 PM
