Old 07-28-2017, 01:21 PM   #57
B T
i have not because the battery isn't here yet. It does not have two indentions in the middle of the tray and it has two threaded holes on one side of the it as well. Dimensionally it looks correct however.
B T is offline   Reply With Quote
Old 08-05-2017, 08:25 PM   #58
T-Steve
Drives: 2014 BRZ
I just did this using a cheap 51R battery and parts from JP Parts. What an easy mod. It seems to have saved about five pounds. Thanks for the tip!
Originally Posted by nikitopo View Post
I am using a Yuasa 44B19L battery:
It is almost half the weight of the OEM battery and still useful in a daily driven car. It fits perfectly in the BRZ RA's battery holder (Japan spec). So, no need for custom solutions.
I replaced the following Subaru parts. Part numbers are for the new ones:
Tray-Battery
82122CA010 x 1
Rod-Battery Fix
82161AG001 x 1
Holder-Battery Fix
82182AG010 x 1
Dimensions of the battery:
Length (mm) 187
Width (mm) 127
Height (mm) 225
Any other battery with similar dimensions will work.
T-Steve is online now   Reply With Quote
The Following User Says Thank You to T-Steve For This Useful Post:
nikitopo (08-22-2017)
Old 08-05-2017, 11:11 PM   #59
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I did it light cheap strong bro
http://www.ft86club.com/forums/showthread.php?t=120937
SuperTom is offline   Reply With Quote
Old 04-06-2020, 01:48 PM   #60
DarkSunrise
DarkSunrise's Avatar
Originally Posted by B T View Post
Hmm, the battery tray I ordered with that part number doesn't look quite the same
Just curious how things went with this. Did you go with a 151R group battery like the one @nikitopo posted? Weight savings? Looks like most 151R batteries are ~24 lbs, but the Yuasa and MagnaPower ones are about 19 lbs.
2022 BRZ Build
2013 FR-S Build
Old 04-06-2020, 09:37 PM   #61
B T
honestly I haven't ever gotten around to it. Kind of worried it will affect my OEM Audio stereo system and startup with supercharger. I would go with one of the 12-15 lb Braille pieces or odyssey when I go through with it.
The Following User Says Thank You to B T For This Useful Post:
DarkSunrise (04-06-2020)
Old 04-06-2020, 09:43 PM   #62
86TOYO2k17
Drives: 2017 toyota 86
Shorai battery, supercharged, with intercooler, and wmi, so two extra pumps and a fail safe gauge, and a scangauge all drawing more power from battery at startup. Over two years, two full winters, zero issues, starts up stronger and faster then oem even without the blower. Seen 20F-100F over that time daily driven. But parked for a week at a time on occasion.
Old 04-06-2020, 09:52 PM   #63
Infinity
Drives: 2016 Scion FR-S
Anyone ever try the Diftech kit?
https://diftech.com/products/frs-brz...raille-battery
Infinity is offline   Reply With Quote
Old 04-07-2020, 01:04 AM   #64
86TOYO2k17
Originally Posted by Infinity View Post
I would never use a braile 6 on a DD might not even have enough CCA to turn over under 35 degrees, and leave you’re lights on for a few mins or don’t start it for a few days and now dead battery.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
Infinity (04-07-2020), Irace86.2.0 (04-07-2020)
Old 04-07-2020, 07:37 AM   #65
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I was checking this kit in the link. It is not clear how you hold the battery in place. They provide 2 screws, but I cannot tell from the pictures if they are used at all.
Old 04-07-2020, 03:18 PM   #66
Infinity
I think the only thing that holds the battery in place is that Velcro strap.
Old 04-07-2020, 03:35 PM   #67
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes. That's what it looks like.
Old 04-07-2020, 04:00 PM   #68
Joon525
Joon525's Avatar
Drives: 2016 BRZ
A bracket is secured to the tray with the 2 bolts.
That bracket is then secured to the car.
https://cdn.shopify.com/s/files/1/11...g?v=1571609574
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
venturaII (04-07-2020)
Old 04-07-2020, 06:27 PM   #69
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm running the PC925. Mostly due to price. I can't justify buying a Braille or Shorai when I can get the 925 for less then 150 bucks and it's still a significant weight savings.
Old 04-07-2020, 09:42 PM   #70
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I agree. I have an 11lb Braille battery, and I only drive 3.5 miles to work or the gym. I have a battery tender that is absolutely necessary. If the car sits for 5-7 days then it may not have enough juice to start. Leave the lights on for a few minutes, and the same thing.
I have a smaller/lighter Shorai battery for the motorcycle. I have let that sit for over 6 months with no tender, and it starts up every time. I would suggest an lithium ion or lithium iron battery over an AGM battery.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
why? (04-12-2020)
battery, daily driver, lightweight battery, track, weight reduction
MAW lightweight battery kit. Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-24-2016 07:57 PM
*BRZ Part Out* KCMachine lightweight battery xDanger_208x Engine, Exhaust, Bolt-Ons 2 03-31-2015 02:40 AM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
OEM shorter lightweight battery bracket? fstlane Tracking / Autocross / HPDE / Drifting 1 03-08-2014 01:26 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 03:01 PM
