#575 |
Drives: White 2014 BRZ
Has it been proven that the new wheel spools up higher and faster, making more pressure? Or just quicker spool since its lighter? I would think the motor spins at a fixed rpm and this what determines max boost pressure. Is the compressor upgrade-able?
JDL Turbo kit - Ecutek, HRI tuned.
#576 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Here goes: It's a quicker spool up due to less mass. Because of that we actually produce more psi because it's at a lower rpm. Even though it's the same max speed. Compressor is upgrade able through Rob. But will you tell the difference? Maybe. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#577 | |
I'm really debating on getting another system to do a twin setup. In theory no reason why it wouldn't work.
#578 | |
Rob has played with that setup. He has a video on YouTube. I'm more interested in what he's cooking up next. I haven't seen or heard anything. But he's always tinkering. Sent from my iPhone using Tapatalk
#579 |
Drives: SWP BRZ
#580 |
Drives: BRZ Limited; GR86
#581 |
Time Traveller
#582 |
#583 |
That is awesome! 10 psi !
On a sad note my voltmeter stopped working tonight :/
#584 | |
V1? Sent from my iPhone using Tapatalk
#585 |
Yeah its used one of the original kits. So about 2 years old the switch seems to work.
#586 | |
Yeah the v1s had issues with the voltmeters. He switched away from that part due to failures. If you can live without it. It will be fine. If you can't... Contact Rob. Sent from my iPhone using Tapatalk
#587 |
Drives: SWP BRZ
weather was 55 - 60 today so i took my car out and had some datalogging
two 3rd gear pull from RPM 3K ~ and one 6th gear cruising. http://www.datazap.me/u/zc06kissther...pull-1st-22016 http://www.datazap.me/u/zc06kissther...og=0&data=1-12 http://www.datazap.me/u/zc06kissther...og=0&data=1-12 i think i am ok but my AFR shows 11.xx when WOT. isnt that little rich? also i noticed my volt meter doesnt go back up to 28.3 when i use boost from using 6th gear on highway. it eventually go back to 28.3 but it takes long time. is this normal? |
#588 |
Not really maybe a little bit but its fine. This the oft right? So it's not going to be prefect. I run 11.8 on ecutek on 93. Iirc I'm at 23 degrees timing. E85 Afr is 12.2 and timing 29 degrees at redline.
Probably shouldn't boost in 6th at least I wouldn't imo. Puts alot of load on the engine. Looks like you have some mild knock as well.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
