Old 02-18-2016, 08:31 PM   #575
stevo585
Drives: White 2014 BRZ
Originally Posted by Sojhinn View Post
Yup.
Has it been proven that the new wheel spools up higher and faster, making more pressure?
Or just quicker spool since its lighter? I would think the motor spins at a fixed rpm and this what determines max boost pressure.
Is the compressor upgrade-able?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 02-18-2016, 08:33 PM   #576
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Here goes:
It's a quicker spool up due to less mass. Because of that we actually produce more psi because it's at a lower rpm. Even though it's the same max speed.
Compressor is upgrade able through Rob. But will you tell the difference? Maybe.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
shaynek (02-19-2016), stevo585 (02-18-2016)
Old 02-18-2016, 08:42 PM   #577
stevo585
Here goes:
That makes sense
I'm really debating on getting another system to do a twin setup. In theory no reason why it wouldn't work.
Old 02-18-2016, 08:49 PM   #578
Sojhinn
Sojhinn's Avatar
That makes sense
Rob has played with that setup. He has a video on YouTube.
I'm more interested in what he's cooking up next. I haven't seen or heard anything. But he's always tinkering.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
stevo585 (02-19-2016)
Old 02-18-2016, 11:33 PM   #579
Gums
Drives: SWP BRZ
Wink
Originally Posted by keen as View Post
I only get up to high 3 psi. Perhaps my RHD car is a factor due to the longer dump cables required.
Nah, it's my 2nd hand dump cables!
Gums is offline   Reply With Quote
The Following User Says Thank You to Gums For This Useful Post:
keen as (02-18-2016)
Old 02-19-2016, 04:37 PM   #580
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Lol imagine having twin supercharger.
shaynek is offline   Reply With Quote
The Following User Says Thank You to shaynek For This Useful Post:
raven1231 (02-19-2016)
Old 02-19-2016, 04:41 PM   #581
DAEMANO
Time Traveller
Many many many torques
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 02-19-2016, 05:09 PM   #582
shaynek
shaynek's Avatar
lol if only! vtec kicked in yoooo
DAEMANO (02-19-2016)
Old 02-19-2016, 09:50 PM   #583
stevo585
That is awesome! 10 psi !
On a sad note my voltmeter stopped working tonight :/
Old 02-19-2016, 10:09 PM   #584
Sojhinn
Sojhinn's Avatar
V1?
Installed Mods:
Old 02-20-2016, 06:57 PM   #585
stevo585
V1?
Yeah its used one of the original kits. So about 2 years old the switch seems to work.
Old 02-20-2016, 07:05 PM   #586
Sojhinn
Sojhinn's Avatar
Yeah the v1s had issues with the voltmeters. He switched away from that part due to failures. If you can live without it. It will be fine. If you can't... Contact Rob.
Installed Mods:
stevo585 (02-20-2016)
Old 02-20-2016, 11:19 PM   #587
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
weather was 55 - 60 today so i took my car out and had some datalogging
two 3rd gear pull from RPM 3K ~
and one 6th gear cruising.
http://www.datazap.me/u/zc06kissther...pull-1st-22016
http://www.datazap.me/u/zc06kissther...og=0&data=1-12
i think i am ok but my AFR shows 11.xx when WOT.
isnt that little rich?
also i noticed my volt meter doesnt go back up to 28.3 when i use boost from using 6th gear on highway. it eventually go back to 28.3 but it takes long time. is this normal?
Old 02-21-2016, 12:23 AM   #588
stevo585
Not really maybe a little bit but its fine. This the oft right? So it's not going to be prefect. I run 11.8 on ecutek on 93. Iirc I'm at 23 degrees timing. E85 Afr is 12.2 and timing 29 degrees at redline.
Probably shouldn't boost in 6th at least I wouldn't imo. Puts alot of load on the engine.
Looks like you have some mild knock as well.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
