Old 11-08-2013, 06:01 PM   #43
ron_n_tx
ron_n_tx's Avatar
Drives: 2013 Scion FR-S - Ultramarine
This worked great - installed Eibach Sportlines today @DIY Austin.
ron_n_tx is offline   Reply With Quote
Old 12-01-2013, 03:05 PM   #44
psk
Drives: scion fr-s
were there any photos to your original post @jeebus ?
psk is offline   Reply With Quote
Old 12-01-2013, 05:05 PM   #45
jeebus
Drives: 2015 Mustang GT (on order)
whoops...I dropped that old web host. I just uploaded the pics directly to the forum now.
jeebus is offline   Reply With Quote
Old 12-01-2013, 05:07 PM   #46
psk
Drives: scion fr-s
thank you! i'll be looking to throw a set of eibach pro's on this month.
Old 01-27-2014, 04:03 PM   #47
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
My Swifts are on their way, this will help greatly with the install.
Does anyone know the correct torque Values for top nuts F&R, bottom shock/strut bolts and sway bar links?
Thanks
F1fletch is offline   Reply With Quote
Old 01-27-2014, 04:42 PM   #48
Stevo22
Stevo22's Avatar
Drives: GR86
Thanks
I think all the torque values are in the DIY darrendriven did that is linked in the first post of this thread. Here is the link again
Stevo22 is offline   Reply With Quote
Old 01-31-2014, 08:16 PM   #49
Scion F ARE S
Drives: Toy car
How would you torque the top hat nut that requires the allen tool? Do you just estimate the amount of torque with your best judgment?
Scion F ARE S is offline   Reply With Quote
Old 02-07-2014, 10:47 AM   #50
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
With a socket (for a pass through socket set), crow foot and torque wrench. And an Allen key to hold the piston rod in place.
Fizz is offline   Reply With Quote
Old 02-24-2014, 12:35 PM   #51
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Originally Posted by CaptainSlow View Post
One additional plus about doing it this way (at least this worked for me...I make no guarantees) is that you don't actually have to remove the front struts. You disconnect the lines and the sway bar and you can pull the strut down and rotate it out far enough to swap the springs and bump stops without removing the strut at all!
I was hoping this was the case. I figured it was possible! Thanks for confirming
bryan767 is offline   Reply With Quote
Old 03-15-2014, 02:53 PM   #52
no chrome
She said member
Drives: fr-s firestorm
Bumping to top for everyone!
no chrome is offline   Reply With Quote
Old 03-16-2014, 09:38 PM   #53
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
I'm confused by this... how does the torque wrench and the crow foot come into play? At first I thought it would go on the allen key, but since that's for keeping the piston for spinning, that can't be what it's for I don't think?
flashburn is offline   Reply With Quote
Old 03-16-2014, 10:04 PM   #54
was385
Drives: MT WRB BRZ Limited, 2007 911s
I believe the people doing it have been grinding down a socket to fit in to the crow foot, so you use it to torque the nut with the Allen key holding the piston still. I didn't want to deal and ended up torquing a bolt to the correct torque and then estimating that feel on the strut with a normal pass through socket wrench.
was385 is offline   Reply With Quote
Old 03-16-2014, 10:21 PM   #55
flashburn
Ah, okay. Yeah I think I'd just be better off doing it by feel then too. Thanks!
Old 03-17-2014, 09:58 AM   #56
oaroyale
Drives: Black BRZ
You don't have to grind the socket with these pass through sockets.
[ame="http://www.amazon.com/gp/aw/d/B00F3ZY4Y0/ref=mp_s_a_1_1?qid=1395064388&sr=8-1&pi=SY200_QL40"]BOSTITCH BTMT72287 Pass Through Socket Set, 65-Piece:Amazon:Home Improvement[/ame]
Use these sockets with a 19mm crowfoot. Make sure to adjust the torque value based on the added length of the crowfoot. You can find the formula on the internet easily. For example, instead of 42ft-lb, I ended up with 38ft-lb for the front.
oaroyale is offline   Reply With Quote
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Exhaust MP/FP (flange/spring bolts) install help! rbizzle004 Engine, Exhaust, Transmission 9 03-04-2013 11:34 AM
East bay shops for spring install? WillBRZ Northern California 9 02-21-2013 02:03 AM
Selling stock strut/spring assembly SleekMachine Brakes, Suspension, Chassis 16 12-13-2012 08:03 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
