Old 03-28-2022, 12:18 PM   #43
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by PulsarBeeerz View Post
I've always run it on both. Reflective insulation on the pan prevents head from soaking into it..
Unless the pan is actually cooler than the air around it, you are doing more harm than good insulating it. So unless your headers are unwrapped and/or uncoated and almost touching the pan, I think it will actually hinder the oil temps. Also stuff like gold foil tape helps only agaisnt radian heat, which you would have none of if the headers are wrapped, but actually hinder the heat dissipation thru the air contact (as you've just added another layer the heat needs to travel thru, and further temperature inside is required to reach the same dissipation outside).
The Following User Says Thank You to Icecreamtruk For This Useful Post:
p1l0t (03-28-2022)
Old 03-28-2022, 10:17 PM   #44
PulsarBeeerz
Drives: JRSC BRZ SOLD
I've run an oil cooler for a while now even before the FI. The oil temps are fine.
PulsarBeeerz is offline   Reply With Quote
Best manifolds (headers) to OFT - OpenFlashTablet petermmdk Engine, Exhaust, Transmission 14 02-09-2021 02:01 PM
RHD/LHD Manifolds secret.squirrel Engine, Exhaust, Transmission 4 03-11-2016 03:31 PM
FA20 Aftermarket Intake Manifolds slava Engine, Exhaust, Transmission 13 03-20-2015 09:49 AM
EGT or O2 logging with UEL exhaust manifolds? burdickjp Engine, Exhaust, Transmission 0 01-23-2015 03:46 PM
Performance manifolds Nitro_FRS Engine, Exhaust, Transmission 20 10-17-2013 12:42 PM
