Old 03-19-2022, 10:30 AM   #1
gpvecchi
gpvecchi's Avatar
Help me choosing between these two manifolds
I'm really debated between those two manifolds, I'll not post the brand for more impartiality. Both of them are 4-2-1.
What do you suggest and why? Thank you!
gpvecchi is offline   Reply With Quote
Old 03-19-2022, 10:48 AM   #2
Lantanafrs2
Drives: 2013 frs red
The merge looks nicer on the bottom one but wdik?
Old 03-19-2022, 12:19 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
Whichever has a history of preforming the best.
PulsarBeeerz is offline   Reply With Quote
Old 03-19-2022, 12:53 PM   #4
whataboutbob
AutoX-10/10ths every run
I'm not an expert on header design, but this page looks like it has a good discussion on header design considerations: https://www.enginelabs.com/engine-te...gn-and-theory/
The main difference between the 2 headers you posted looks to be the length of the primary runners. I'd suggest researching that aspect of the header design.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
blsfrs (03-23-2022), Lantanafrs2 (03-19-2022)
Old 03-19-2022, 01:39 PM   #5
Espi
Espi's Avatar
Drives: 17 BRZ
From what I've seen the longer runner style header is what gives this platform better performance - Think Ace, JDL, Nameless, P&L all longer style runners giving great numbers. I'd go for the bottom set
Espi is offline   Reply With Quote
Old 03-19-2022, 01:51 PM   #6
gpvecchi
gpvecchi's Avatar
That's what I read, anyway, while the second one in all the dynos I found gives a great result at high RPM, but a little loss of torque under 3000 RPM, the first one seems the opposite.
Both use 45mm primaries.
Old 03-19-2022, 01:53 PM   #7
p1l0t
p1l0t's Avatar
UEL because it sounds like a true Subaru
Celica00 (03-24-2022)
Old 03-19-2022, 02:35 PM   #8
Brz-123
The first one looks like the prev gen ace which was the best. It's a 4-2-1 while the bottom one is 4-1. The way the latter looks is it dissipates too much heat and hence all the insulation even below the oil sump.
I will go with the former not the latter.
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 03-19-2022, 02:51 PM   #9
PulsarBeeerz
Look closer, they are both 4-2-1. One should run insulation on the oil pan regardless of header design.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Brz-123 (03-21-2022)
Old 03-19-2022, 02:54 PM   #10
gpvecchi
gpvecchi's Avatar
EL, because I own a Toyota! :-D
The Following 8 Users Say Thank You to gpvecchi For This Useful Post:
Celica00 (03-24-2022), Espi (03-19-2022), Jdmjunkie (03-19-2022), p1l0t (03-19-2022), saltywetman (03-24-2022), soundman98 (03-23-2022), venturaII (03-31-2022), x808drifter (03-19-2022)
Old 03-19-2022, 02:59 PM   #11
p1l0t
p1l0t's Avatar
Well that would be the first one then but UEL sounds more cool.
Old 03-19-2022, 03:54 PM   #12
gpvecchi
gpvecchi's Avatar
Ehm, not my taste, it sounds like an Harley...
The Following User Says Thank You to gpvecchi For This Useful Post:
Old 03-19-2022, 04:04 PM   #13
p1l0t
p1l0t's Avatar
Then I guess you have your answer, you're welcome.
gpvecchi (03-20-2022)
Old 03-20-2022, 12:46 PM   #14
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Well the top one is HKS and it's a decent header. I'm not familiar with the bottom. But I'm sure either or will only net very little difference.
MS, CSCS, TSAC-F, CPT
Best manifolds (headers) to OFT - OpenFlashTablet petermmdk Engine, Exhaust, Transmission 14 02-09-2021 02:01 PM
RHD/LHD Manifolds secret.squirrel Engine, Exhaust, Transmission 4 03-11-2016 03:31 PM
FA20 Aftermarket Intake Manifolds slava Engine, Exhaust, Transmission 13 03-20-2015 09:49 AM
EGT or O2 logging with UEL exhaust manifolds? burdickjp Engine, Exhaust, Transmission 0 01-23-2015 03:46 PM
Performance manifolds Nitro_FRS Engine, Exhaust, Transmission 20 10-17-2013 12:42 PM
