Software Tuning Discuss all software tuning topics. |
#43 | |
Drives: FR-S Whiteout
Thread on thermostats: http://www.ft86club.com/forums/showthread.php?t=9599
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 08-02-2017 at 10:32 PM. |
#44 |
Drives: Toyota 86 GTS
Aftermarket quality is generally garbage compared to OEM, so you risk wasting a bunch of money, time and energy swapping it out, then back again when it becomes stuck open, stuck closed or otherwise doesn't work as advertised.
I wouldn't take the word of the likes of Cosworth. Any minimal tuning they do is only to enable them to market and sell hardware. |
#45 |
This company sells a 180*f thermostat for the 86. Are they any better than Mishimoto? Maybe?
[ame="https://www.youtube.com/watch?v=YIJx-ks2wN0"]https://www.youtube.com/watch?v=YIJx-ks2wN0[/ame] Edit: There are actually quite a bit of bad reviews saying it gets stuck open. here is one https://www.gmforum.com/general-gm-c...mostat-269434/
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 08-03-2017 at 12:50 AM. |
#46 | |
Drives: Silver Coupe with a Boxer
Under sustained loads like you see on a track does a lower temp thermostat actually drop coolant temps enough to matter? I'd think that after a few laps any advantage from opening the thermostat sooner would be gone because you're dumped enough heat into the system that the cooling capability of the radiator is your biggest limitation. But I haven't actually seen data on it. |
#47 | |
Intent > Content
cowardice is the mother of cruelty. |
#48 |
Drives: Toyota GT86
This is what it looks like now:
3rd and 4th gear: ![]() Lots of other pulls in there (3 logs): http://datazap.me/u/tor/tor-227-0-60...zoom=8064-8405 It pulls some timing here and there, but nothing major. I probably lose some power (at least in lower gears) by running this rich up top and to the increased TCPC which I extended down in the low rpm with -1 deg. But I think I am happy with this and I suppose this will hold up on track as well, there is no real noticeable performance difference either. In fact, in 4th it feels better if it's not placebo, but I swear I could feel it pulling timing before.
#49 |
I'm curious about your oil cooler setup and how its mounted. It seems like your IAT's are not effected negatively at all.
Intent > Content
#50 | |
Drives: Toyota GT86
Here from my thread: http://www.ft86club.com/forums/showp...4&postcount=32
The Following User Says Thank You to Tor For This Useful Post: | solidONE (08-05-2017) |
#51 | |
I guess that the good part living in cooler climates vs hotter. Cars can make a bit more power.
Intent > Content
#52 | |
Drives: Toyota GT86
#53 | |
http://datazap.me/u/tor/tor-227-0-60...ark=9712-14210
Intent > Content
#54 | |
Drives: Toyota GT86
#55 |
Here is a data log I took while driving in the Glendora mountains after a fresh re-flash. AC on full blast for the log. fairly new 0w-30 Castrol oil and kinda warm weather. Sans additional oil cooling.
http://datazap.me/u/solidone/z7-kc2a...data=1-4-12-13 If you look at the oil temp relative to the coolant temp. Coolant temp equilibrium with the stock t-stat is 195~200*f. Coolant does not go much higher than 200*f while oil was climbing toward 260*f. This supports the assumption that a cooler thermostat may have a positive effect on knock resistance. If the equilibrium was at 185~195*f one would assume that all components cooled by coolant will also drop in temps relative to the stock numbers under the same conditions. Only problem is finding a reliable aftermarket t-stat...
Intent > Content
#56 | |
Drives: Toyota GT86
If you do go ahead and do this, it would be very interesting to see your results!
High performance Vortech at track | Sonolin | Forced Induction | 41 | 03-18-2016 07:19 PM |
High negative FLKC values on the highway | RIP.S2000 | Software Tuning | 4 | 12-18-2015 10:36 PM |
Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 12:48 AM |
Acceptable helmet suggestions. | jadewbj | Tracking / Autocross / HPDE / Drifting | 40 | 10-03-2012 03:59 PM |
High Plains Raceway track day | Rejor11 | Tracking / Autocross / HPDE / Drifting | 4 | 08-21-2012 09:02 AM |
