Drives: 2013 Whiteout Scion FRS
Acceptable helmet suggestions.
I want to attend my first autocross soon so of course I need a helmet. Not looking to get too crazy so I want a helmet that won't break the bank but still be safe.
I figure since it is just AutoX for now and not full on track driving I don't need the best of the best. Any suggestions? |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Need an M or SA rated helmet. Best affordable M rated you can get at http://www.cyclesportscenter.com/ on North JYP. They sell a good HJC for $129/139 (size dependant). Just dont get the XXXL as it isn't Snell M rated.
If you are running with CFRC, any helmet will do. Martin or SCCA will require this M rating minimum.
#3 | |
http://www.revzilla.com/motorcycle/hjc-cs-r2-helmet |
i'm sorry, what?
Drives: Canada
make sure whatever helmet you get has a SNELL sticker on it, DOT won't cut it for most autocross events in both US and CANADA
keep in mind the following some helmets are on sale because they are old, the snell standard is at 2010 right now, so a SNELL 2005 or 2000 will be cheaper (but that means it's been sitting on the shelf for that long). Be careful of rogue seller who may try to push SNELL95 or even older on you. Futhermore, SCCA right now allows a SNELL2000 or newer helmet, which could change at any point. This means that it's best to buy a newer helmet which will ensure that you can use it for a longer time. (Even if it gets old you can use it as a spare or donate for passenger use) In terms of price, any SNELL rated helmet is good enough to protect you from pretty much from anything you'll experience in autocross, so unless you plan on doing track racing later on you really can go and get the cheapest helmet. More money will, however, get you a lighter helmet. Spend 200-300 dollars more today but get more comfort for the next 5-7 years, fatigue is the number one reason for mistakes and shitty performance, so think about that. Open face vs Closed face: Open face is less claustrophobic and generally lighter, but offers little face protection compared to a full face. Like something hitting your mouth/chin, like the steering wheel or if you forget or don't turn off your airbag, imagine the airbag going off as your hand is crossed and you get your own fist accelerating towards you face at a gajillion miles per hour. M vs SA M helmets are designed for one big crash, hence why they are marketed as motorcycle helmets, M SA helmets are designed for many smaller dings and bangs, for use mostly in CAGED cars where you bang your helmet on stuff without even realising it. Happy Helmet Hunting
| The Following 4 Users Say Thank You to 7thgear For This Useful Post: |
Grip>Drift
Drives: FRS
Most AutoX (SCCA or Club) should have loaner helmets.
My suggestion is to use those for a while to see if you really like the sport and to get a feel of what you like and don't like about helmets before you spend your own green on one.
I can't see if the one I posted is Snell rated.
I want to spend 100-150 max and prefer a full face, any suggestions? |
This one says it is Snell rated but no year.
http://www.jafrum.com/Motorcycle-Hel...ce-Helmet-Gold There is this one also. http://www.jafrum.com/Motorcycle-Hel...T-Helmet-Solid |
Drives: Some rust bucket
if you're ever interested in buying a more premium full face helmet, i'm selling my arai rx-q size small in white. i've only used it a couple times. it's a M rated snell 2010 helmet.
Dodging cones
Any current helmet with an M will be 2010. Haven't run across any new 2005s. That looks a lot like my HJC. Go test fit it first, do NOT go by other helmet's size ratings. This HJC fits more snug that it's rating implies. I'm a XL in most helmets, XXL in others. This HJC is almost uncomfortably tight in XXL. I needed it in XXXL but that size wasn't M rated.
#10 | |
i'm sorry, what?
Drives: Canada
just keep in mind all i said and make your own decision, at the end of the day you don't actually have that large of a choice. Personally though, i own a BELL helmet. My first helmet was HJC but it was big and clunky.
#11 |
Drives: 4Runner
http://www.saferacer.com/zamp-racing...productid=2405 SA2010. $169.95 Full face
Here's a place in FL that has some. http://www.magnaracing.com/index.php...a37ko2ioovj6b0
diirk
waiting on a Neptune Premium MT |
#12 |
I think I am going to hit up seminole powersports and try on some helmets.
#13 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
Here is the helmet I use, got it from SoloRacer it is SA certified and pre drilled for Hans device.
http://www.soloracer.com/pyrotectopen.html
#14 | |
Drives: 86
The Large Pyrotect was WAY too small. It was fine around the cheeks, but it wouldn't push all the way down on my head. My brother, who wears medium helmets, couldn't even get it to fit on him. This has been the only helmet that didn't fit us. Did you find it was true to size? Does it push all the way down onto your head? I'm just curious...because I was a little disappointed I had to send it back on my dime, when I really felt it was an issue with this particular helmet. |
| Help Buying a Helmet? | SeattleJeremy | Tracking / Autocross / HPDE / Drifting | 22 | 01-24-2016 01:21 PM |
| Helmet recommendations? | denverizzles | Tracking / Autocross / HPDE / Drifting | 9 | 09-10-2012 01:55 PM |
| I need a suggestion for a helmet for AutoX | ngabdala | Tracking / Autocross / HPDE / Drifting | 24 | 09-03-2012 02:48 AM |
| Helmet painting? | Mitch | Tracking / Autocross / HPDE / Drifting | 1 | 09-02-2012 03:44 PM |
| Larger Rear Wheels - Tacky or Acceptable? | Orly | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 02-28-2010 11:16 PM |
