#477 | |
Road-hole
Drives: 2013 Whiteout FR-S
The water heats up faster than the oil...
Jaden |
#478 | ||
Drives: RX-7 / BRZ
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged Last edited by Kiske; 05-20-2015 at 07:32 PM. |
#479 |
Drives: vrooom...
#480 |
Drives: RX-7 / BRZ
Yes via the support form> get a ticket> email. My rep was Zach Tempone FWIW. Explained to him what I was doing and how I'd love to add their oil cooler to my setup. 1 week later...
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#481 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I know this isn't $15 but isn't something like this similar and will clear the OEM oil cooler lip (plus it is thermostatic).
[ame="http://www.amazon.com/Derale-15732-Thermostatic-Sandwich-Adapter/dp/B004XONTSO/ref=sr_1_3?ie=UTF8&qid=1432183498&sr=8-3&keywords=derale+thermostatic"]Amazon.com: Derale 15732 Thermostatic Sandwich Adapter Kit: Automotive[/ame] |
#482 | |
Drives: Nevermorange FRS
Compare Amsoil as a point of reference. The 0w-30 has a 100C viscosity of 10.5 cSt The 5w-30 has a 100C viscosity of 10.4 cSt The 10w-30 has a 100C viscosity of 10.4 cSt Now what about at cold(der) temps? 40C 0w-30 = 58.2 5w-30 = 59.9 10w-30 = 62.3 So with that being said, I'd definitely choose the 0w-30 but the difference between a 5w and 0w is very small.
PRO86 | STL | LuckyDog
#483 | |
Drives: bmw
now for your next trick, if you could tell me how to make this go away for good... http://www.ft86club.com/forums/showthread.php?t=30879
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#484 |
Sarcastic SOB
Considering buying this oil cooler, any input?
Having a tough time accepting that it will cost me $800 thereabouts to get a name brand oil cooler shipped here excluding install.
Found this on Ebay: http://www.ebay.ca/itm/New-13-row-10...55646f&vxp=mtr Aside from a lack of supplier support and apparently no mounting hardware for the radiator (I can figure that out), any reason I shouldn't buy this?
#485 |
Drives: bmw
adding some more to my post 474 - http://www.ft86club.com/forums/showp...&postcount=474
i went to gingerman today, it got up to around 80 or so ![]() it's amusing that you can tell by oil temps that my last 2 sessions were nice and my others were full of trains and messes. who did not stick it out through the last 2 sessions of the day, thankfully. my oil temp (sandwich) and data temp (obd2, wherever that sensor is) are off, i think putzing around the gauge was higher? it certainly seems to be the case here. max oil 251. but if you look at my gauges (pressure then oil) ![]() ![]() the oil seems higher than my max of 251 in the data. i thought i saw it getting near 255 maybe + but def not 260 or over. in any case here's a snapshot from the helmet cam vid: ![]() this is from the long straight at gingerman, so top out 3rd then here i'm topping out 4th. i look to be about 7000+ rpms. my understanding is the desired pressure would be 80 psi, but i don't seem to be in too bad of shape at what appears to be around 60 psi.
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com Last edited by sickmint79; 05-24-2015 at 01:26 PM. |
#486 |
not playing cards
Is that a block8head pod? Is it a good fit? Issues?
#487 |
Drives: bmw
yes it is; kinda; i'm butterfingers and horrible at installing things, i have a slight fitment issue in that i think the power/sensor cables for both gauges take up more space then the pod had an area cut away for, so it's not fitting as nicely as it could. i am lazy and it's not flying around on a race track though so i live with it. good enough for me to not touch. wouldn't hesitate to buy again.
#488 | |
not playing cards
#489 |
Drives: 2013 BRZ black
tl:dr Is this cooler a donut style oil-to-water cooler as described in the following link?
http://www.mocal.co.uk/FAQ.html Anyone noticing oil pressure drops as a result of running this? TIA |
#490 |
Drives: bmw
i'm under the impression ours doesn't change the oil flow as much as that one? not sure.
in any case i have my oil pressure in post 486 which i think is pretty good for the temp and condition.
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
