#435 | |
also, we are not advocates of replacing the factory damped crank pulley with with non-dampened aluminum replacements that do a poor job of neutralizing harmonics in the crankshaft. |
#436 |
because the crank pulley adapter is toothed, there is no belt alignment issues (as there would be with a serpentine belt) as long as the adapter sits within +/- 5mm of its position using the stock crank pulley.
#437 | |
the blower is set up to hit 10.2psi with a max engine RPM of 7800. we have a smaller pulley set-up where the engine redline is set for 7300rpm engine that makes about 13psi boost and about 15whp more in the midrange and 30whp more peak |
#438 | |
That Guy
Drives: 2013 asphalt FRS MT
#439 | |
That Guy
#440 | |
Thank you for the info! |
#441 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
#442 |
we havent had a chance to look at this....we have designed it for use with the stock damper....i'm sure other dampers can be used, but at this point we will have to defer to enthusiast base to determine all the nuances of what parts can be used instead
#443 |
1337
Drives: 2013 BRZ WRB S/C
@gmsii
Can you comment on replacing the serpentine belt? I'm guessing the whole supercharger has to come off, how time consuming is that process? Secondly, how do you get at the air filter if you want to clean or replace, is there any way of avoiding removing the bumper or is that the only way? Also, how accessible is the oil filter? I already have trouble with my, albeit somewhat antiquated, oil filter wrench with the stock setup - this looks quite a bit more cramped. |
#444 | |
regarding the air cleaner...we decided to place it in the cold air area of the bumper for performance and space reasons....removing the bumper is not very hard and filter only needs to be cleaning every 30,000-50,000 miles as for oil filter access....its not a problem...dont know about using a p-clamp style filter wrench, but definitely not a issue with a socket style oil filter wrench or even just using your hand with a piece of sand paper |
#445 | |
Drives: VW
Very detailed info. Nice results. Thanks! So starting from a bone stock FA20 these are the results for your reg. $5095.00 full tune kit? Using the ~ 4.5hr install time ~ $400-$500 for a shop to integrate. The gearbelt looks great, what will that retail for ? Just as a precaution. |
#446 | |
the double sided cogged belt will be available for about $80 |
#447 |
Drives: Subaru BRZ
SO, SEMA's over. I want updates.
When are we doing finale paiment? When the kit are supposed to be mail? Just to make sure, the msrp price is 4495 msrp for a tuned kit. For the first thirty it's still 3695 minus the 319$ deposit for a tuned kit? Is there a choice of color for the piping? What are the upgrade that can be made execpt puting a C38 to upgrade power? |
#448 | |
$3895+ shipping and tax (if applicable) is for the base kit w/ ecutek map $4495+ shipping and tax (if applicable) is for tuned base kit w/ecutek hardware and mapping the piping comes in gunmetal metallic silver...its easy enough to spray paint or powder coat easiest upgrade will be changing to a smaller pulley...this brings the boost up from 10.2psi to 13psi....but requires the rev limiter to be lowered to 7300rpm....this upgrade nets between 15-30whp ship date is the last week of this month...we are waiting for some final parts to come that arent expected to be received until Nov 21 a customer service rep will call or email every single customer to let them know what all the options and add-ons are available at that point |
| [TX] DFW General Discussion | feedbag | Southwest | 1488 | 06-18-2022 07:25 PM |
| HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 03:28 PM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 05:57 PM |
| Rotrex kit - why no build? | MindtheGap | Engine, Exhaust, Transmission | 5 | 10-26-2012 07:01 PM |
