Old 11-06-2013, 05:37 PM   #421
grostoine
Drives: Subaru BRZ
My P&L headers wont clear the pulley. I have 35 at the farthest point and 20 a the closer point. And I have a perrin pulley...
very desapointed
grostoine is offline   Reply With Quote
Old 11-06-2013, 05:46 PM   #422
gmsii
gmsii's Avatar
Originally Posted by grostoine View Post
My P&L headers wont clear the pulley. I have 35 at the farthest point and 20 a the closer point. And I have a perrin pulley...very desapointed
we'll give you a great deal on a Skunk2 header when it comes out
gmsii is offline   Reply With Quote
Old 11-06-2013, 05:55 PM   #423
grostoine
Drives: Subaru BRZ
Better be a real BIG deal because money doesn't grow on treee
Old 11-06-2013, 06:59 PM   #424
gmsii
gmsii's Avatar
Below is comparison of stock vs KW kit with stock header and exhaust
Below is boost graph...peak boost is 10.23psi @ 7750rpm
From the data below, you can see that air temp increase over ambient air temp is only about 10*c (18*F)
The Following 4 Users Say Thank You to gmsii For This Useful Post:
Calum (11-08-2013), digital_assassin (11-06-2013), normancw (11-06-2013), TrogDor the Burninator (11-06-2013)
Old 11-06-2013, 07:01 PM   #425
grostoine
Drives: Subaru BRZ
So when can we expect to have the kit in the mail?
Old 11-06-2013, 07:06 PM   #426
CSG Mike
CSG Mike's Avatar
Why does the boost dip at 6500-7000 RPM? Is this what causes the dip in output up top?
Old 11-06-2013, 07:44 PM   #427
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Interesting positive results this far. The whole header thing is and will be abit of a negative for some folks however for sure. Regardless how much difference power wise between stock header versus whatever aftermarket brand isn't necessarily important. At least for those folks that are after a certain exhaust note that only some aftermarket headers produce.
Old 11-06-2013, 09:21 PM   #428
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
When will you release the header? I'm looking to purchase a header over the winter as I prepare for NASA Time Trials this spring!
And hey - really liking - and am highly impressed -with this kit. Thanks for all your info @gmsii
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 11-06-2013, 10:07 PM   #429
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
More Phastek closeups from the Seibon SEMA Car
Got some more closeups of the kit, like the pulley that goes on the crank. Enjoy! BTW that is a nice plot on 91. Got any 93 goodness?
It appears this kit doesn't have the oil cooler, and the oil reservoir is relocated. I also have no idea where the MAF sensor is; I reckon its under the passenger side headlight from following wires haha. This must not be the final kit. The blower belt assembly sits pretty close to the accessory belt, but it should be fine. Overall its a very clean kit, has caught my attention
F1point4 is offline   Reply With Quote
The Following 8 Users Say Thank You to F1point4 For This Useful Post:
akuhei (11-06-2013), Calum (11-07-2013), cobrabyte (11-08-2013), CSG Mike (11-06-2013), grostoine (11-06-2013), normancw (11-06-2013), RUNAMUK (11-06-2013), TrogDor the Burninator (11-06-2013)
Old 11-07-2013, 01:47 AM   #430
gmsii
gmsii's Avatar
Originally Posted by normancw View Post
Looks nice! Is there enough room to fit an oil cooler filter adapter?
skunk2 will be launching a complete oil cooler kit around the same time the kit is released....we will be offering a special discount to all KW BRZ SC kit owners...special price should be under $500 complete
the sandwich adapter will also be available seperately for under $99 retail for those who all ready have all the other oil cooler components
robispec also sells a sandwich adpater that will also work
The Following User Says Thank You to gmsii For This Useful Post:
normancw (11-07-2013)
Old 11-07-2013, 03:57 AM   #431
Izurath
Drives: Toyota GT86
Originally Posted by utekineir View Post
where did that sc oil reservoir get relocated to?
The SC oil reservoir is between the battery and the power brace. ( Top left on the picture )
Izurath is offline   Reply With Quote
Old 11-07-2013, 05:38 AM   #432
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm really surprised to see you've just tacked another pulley onto the stock pulley. You could achieve much better quality control over the axial position avoid possible angular misalignment issues by replacing the stock pulley with one that incorporates both rings. Also weight gains could be kept low with proper design and material choices.
Old 11-07-2013, 06:54 AM   #433
OICU812
Just a dude
OICU812's Avatar
Question.. If the drive pulley for sc belt is coming off crank pulley what if the customer has a aftermarket one such as a Raceseng, kart boy, Perrin? Some of these such as raceseng like I have are faced very different then stock one.
Old 11-07-2013, 09:00 AM   #434
utekineir
blowhard
Drives: frs, project forester
Good looking out, thanks,
You mustve been incredible at wheres waldo.
If its going to be sandwiching a new one on at the end wouldn't doubt if the only fitment they will confirm is stock.
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
F1point4 (11-07-2013)
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 08:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 06:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 08:01 PM
