#29 | |
not playing cards
Done properly, the battery is never disconnected from the BCU/ECU. Plenty of tech/mech savvy owners here.
#30 | |
#31 | |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (01-15-2016) |
#32 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Well, Kkobe2 stated this:The battery died once in a camping trip and never was the same again taking a few more cranks to start up.
In my experience, even a known good newer battery, once discharged fully, often never recovers fully...and may need replacement just about any time thereafter. Additionally something may have been left on, causing a draw, just recently on that car. I do know that the dome light, if left in the manual on position, does not shut it self off. There may be also, a position of the headlamp switch, in which self shutoff does not happen at all within minutes of turning off the ignition. |
| The Following User Says Thank You to ToySub1946 For This Useful Post: | Ultramaroon (01-14-2016) |
#33 |
Drives: 2015 CWP BRZ Limited
One guess that I have is that a lot of these cars are Limiteds. The keyless entry draws power, and can really drain a battery down if you leave a key within range. There's no free lunch as far as radio frequency Tx/Rx goes.
| The Following User Says Thank You to jawn For This Useful Post: | Tcoat (01-15-2016) |
#34 | |
not playing cards
Maybe frs owners are better at turning off all the things.
#35 |
not playing cards
Is there a way to tell if the transponder is active? Blinky light or something?
#36 | |
The transponders are sending signal at all times not just when a fob is close to the car. That is how they work after all.
#37 |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
The battery died over Christmas on my '13 BRZ Sport-Tech (~Limited in the US but with Canada-only, crappy Pioneer AVIC head unit). It is our DD but our commute is only 11km/7mi each way, so it doesn't get a lot of charging. It only has 18,500km/11,500mi on it, though as others have observed battery life is more related to charge/drain cycles than mileage. But with only a week without driving it, sitting outside in temperatures mostly above freezing, it still kind of surprised me.
The only problem with changing the battery was that AVIC wanted the security code. My car was a dealer demo, so the dealer originally entered the code and never mentioned it to me. Fortunately they just picked "00000", lol. I can't say I noticed any difference in engine characteristics that I would associate with ECU learning. The 'average fuel economy' indication is way worse though. Not sure if that is real yet. I'll have to take her for a highway cruise to be sure.
Anything worth doing is worth doing twice...
#38 |
Oh, and to @Tcoat's point, I tried charging the OEM battery first with no luck at all. I'd never had any other problems with the battery before. I can't say whether it was defective or not.
#39 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (01-15-2016) |
#40 | |
Some interesting reading: http://mathscinotes.com/2013/02/battery-freezing-math/ So, the electrolyte in a "typical" lead-acid battery could freeze at -5ºC at or below around 2 moles/kg, which is apparently what would would see in a discharged battery. I always thought it would have be a significantly colder.
| The Following 2 Users Say Thank You to Talus1 For This Useful Post: | Tcoat (01-15-2016), Ultramaroon (01-15-2016) |
#41 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Ever find what was wrong?
| Bad Emergency Jack? | JDMenrique | Issues | Warranty | Recalls / TSB | 35 | 11-27-2015 07:55 PM |
| Emergency brake button?? | Borzy | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-13-2015 08:18 PM |
| EMERGENCY I NEED HELP PLEASE | kiname | Southern California | 25 | 07-09-2014 11:41 PM |
| ECUTEK ECU Emergency | gdrider77 | Software Tuning | 6 | 12-18-2013 02:28 PM |
| Emergency help!! | Howardwei | Engine, Exhaust, Transmission | 3 | 08-16-2013 04:42 PM |
