Old 08-16-2013, 02:51 PM   #1
Howardwei
Emergency help!!
Sorry Guys if you disagree!
I just now flashed my ECU using Ecutek. But how do you unplug the cable.. I try to pull it it doesn't seem to come off. Is there a latch somewhere?
Howardwei is offline   Reply With Quote
Old 08-16-2013, 03:42 PM   #2
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Just pull it straight down.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-16-2013, 03:44 PM   #3
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
What he said.
JimmyMac is offline   Reply With Quote
Old 08-16-2013, 04:42 PM   #4
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
This. The first few times it may be a pretty tight fit and you may need to GENTLY wiggle the connector while applying steady downward pressure. No latches, no worries. Good luck!
Nightbringer is offline   Reply With Quote
Bad Emergency Jack? JDMenrique Issues | Warranty | Recalls / TSB 35 11-27-2015 07:55 PM
Emergency brake adjustment? F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-26-2013 10:59 AM
TV Station's Emergency Alert System Hacked, Warns of Montana Zombie Apocalypse JPxM0Dz Off-Topic Lounge [WARNING: NO POLITICS] 8 02-17-2013 11:12 AM
Grinding / Shaking under emergency braking Kurenai Issues | Warranty | Recalls / TSB 16 11-05-2012 09:52 PM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
