Old 01-14-2016, 09:04 PM   #29
Have you noticed though that almost all of these dead battery issues have been BRZs with only a couple of FRSs? I strongly suspect that there is something about the BRZ options that is causing a problem. What it is I do not know but there is something up. The difference in numbers is more that I would call a coincidence especially when you consider the smaller number of BRZs that exist.
No, I haven't noticed because, except for cosmetic differences, I consider them the same vehicle. It's true, though, they have different accessories. We could take a poll of owners' measurements of standby current. Would be interesting.
Done properly, the battery is never disconnected from the BCU/ECU. Plenty of tech/mech savvy owners here.
Old 01-14-2016, 09:52 PM   #30
It would certainly be interesting. I know that for all intents they are the same but I would expect to see more or at least as many FRs if it was an issue common to both. Statistically for more BRZs to have the issue it would say something is different (or just a very odd coincidence of course).
Old 01-14-2016, 10:18 PM   #31
No, you raise a very good point. Electrically, they're quite different. The 10:1 frs-to-brz relationship makes it highly unlikely for it to be a coincidence.
Tcoat (01-15-2016)
Old 01-14-2016, 11:13 PM   #32
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Well, Kkobe2 stated this:The battery died once in a camping trip and never was the same again taking a few more cranks to start up.
In my experience, even a known good newer battery, once discharged fully, often never recovers fully...and may need replacement just about any time thereafter.
Additionally something may have been left on, causing a draw, just recently on that car.
I do know that the dome light, if left in the manual on position, does not shut it self off.
There may be also, a position of the headlamp switch, in which self shutoff does not happen at all within minutes of turning off the ignition.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Ultramaroon (01-14-2016)
Old 01-14-2016, 11:30 PM   #33
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
One guess that I have is that a lot of these cars are Limiteds. The keyless entry draws power, and can really drain a battery down if you leave a key within range. There's no free lunch as far as radio frequency Tx/Rx goes.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Tcoat (01-15-2016)
Old 01-14-2016, 11:32 PM   #34
True.
Maybe frs owners are better at turning off all the things.
Old 01-14-2016, 11:48 PM   #35
Is there a way to tell if the transponder is active? Blinky light or something?
Old 01-15-2016, 05:34 AM   #36
I disagree. If a battery dies because it is defective then yes it may never be the same again once charged. A battery that dies simply because it was drained should be as good as new once charged back up. There is nothing about draining a battery of charge that causes damage.
The transponders are sending signal at all times not just when a fob is close to the car. That is how they work after all.
Old 01-15-2016, 07:15 AM   #37
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
The battery died over Christmas on my '13 BRZ Sport-Tech (~Limited in the US but with Canada-only, crappy Pioneer AVIC head unit). It is our DD but our commute is only 11km/7mi each way, so it doesn't get a lot of charging. It only has 18,500km/11,500mi on it, though as others have observed battery life is more related to charge/drain cycles than mileage. But with only a week without driving it, sitting outside in temperatures mostly above freezing, it still kind of surprised me.
The only problem with changing the battery was that AVIC wanted the security code. My car was a dealer demo, so the dealer originally entered the code and never mentioned it to me. Fortunately they just picked "00000", lol. I can't say I noticed any difference in engine characteristics that I would associate with ECU learning. The 'average fuel economy' indication is way worse though. Not sure if that is real yet. I'll have to take her for a highway cruise to be sure.
Anything worth doing is worth doing twice...
Talus1 is offline   Reply With Quote
Old 01-15-2016, 07:19 AM   #38
Talus1
Talus1's Avatar
Oh, and to @Tcoat's point, I tried charging the OEM battery first with no luck at all. I'd never had any other problems with the battery before. I can't say whether it was defective or not.
Old 01-15-2016, 08:19 AM   #39
In your case it probably froze up after discharging. Even though our day temps have been above zero it has dropped far enough at night to freeze up a dead battery. Once frozen they will likely never work again.
Ultramaroon (01-15-2016)
Old 01-15-2016, 06:38 PM   #40
Talus1
Talus1's Avatar
Still, it surprised me. The temperature was above freezing, day and night, for the entire week except the morning we returned and even then it only got down to -5ºC. (Gotta love the Environment Canada website!) I've never had a battery problem in such mild conditions before. It must have been pretty flat, which really does beg the question about parasitic loads on the BRZ. One day when I have nothing better to do, maybe I'll hook up the ammeter and start pulling fuses.
Some interesting reading:
http://mathscinotes.com/2013/02/battery-freezing-math/
So, the electrolyte in a "typical" lead-acid battery could freeze at -5ºC at or below around 2 moles/kg, which is apparently what would would see in a discharged battery. I always thought it would have be a significantly colder.
The Following 2 Users Say Thank You to Talus1 For This Useful Post:
Tcoat (01-15-2016), Ultramaroon (01-15-2016)
Old 01-15-2016, 09:24 PM   #41
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Ever find what was wrong?
Bad Emergency Jack? JDMenrique Issues | Warranty | Recalls / TSB 35 11-27-2015 07:55 PM
Emergency brake button?? Borzy Cosmetic Modification (Interior/Exterior/Lighting) 2 10-13-2015 08:18 PM
EMERGENCY I NEED HELP PLEASE kiname Southern California 25 07-09-2014 11:41 PM
ECUTEK ECU Emergency gdrider77 Software Tuning 6 12-18-2013 02:28 PM
Emergency help!! Howardwei Engine, Exhaust, Transmission 3 08-16-2013 04:42 PM
