Old 01-13-2016, 11:49 AM   #1
Kkobe2
Drives: 2015 Series.Blue
Emergency dead car!
My car died I hooked it up to jumper cables nothing happened it's push start and when I hit the button absolutely nothing happens. Need help!! Should I go change the battery?? Reconnect the wires??
Kkobe2 is offline   Reply With Quote
Old 01-13-2016, 12:04 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Reconnect which wires?
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 12:04 PM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Did you try disconnecting and reconnecting the battery?
Instagram: trevor.parque
Tcoat (01-13-2016)
Old 01-13-2016, 12:17 PM   #4
Did you check the battery in the fob or at least try the backup method in the owner's manual? I believe you just touch the fob to the metal ring around the button but am not positive.
Old 01-13-2016, 12:28 PM   #5
Kkobe2
I did try to hold the key to the button nothing. Reconnect the battery connection wires. I did not try that yet
Old 01-13-2016, 12:32 PM   #6
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Wait, did you disconnect your car's (supposedly dead) battery from the car? You should not do that.
mdm is offline   Reply With Quote
The Following 2 Users Say Thank You to mdm For This Useful Post:
carczar87 (01-13-2016), jawn (01-13-2016)
Old 01-13-2016, 12:37 PM   #7
Kkobe2
Disconnecting battery and will post update thanks!
Old 01-13-2016, 12:45 PM   #8
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
LOL, what is going on..
Anyway, quick excerpt from the manual that might help:
PandaSPUR is offline   Reply With Quote
Old 01-13-2016, 01:40 PM   #9
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
if I install my intake,do i need to do the step above?
FR-Sky is offline   Reply With Quote
Old 01-13-2016, 01:48 PM   #10
kbye
kbye's Avatar
Drives: 2014 FR-S
I don't know what's real anymore.
kbye is offline   Reply With Quote
The Following 6 Users Say Thank You to kbye For This Useful Post:
8R6 (01-13-2016), brandonblt2 (01-15-2016), El Guapo (01-13-2016), PandaSPUR (01-13-2016), tcroft91 (01-15-2016), wireman957 (01-14-2016)
Old 01-13-2016, 01:49 PM   #11
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I just installed a new battery in my car last weekend. (BRZ pushbutton start)
I did not have to do anything at all special.
It even remembered my radio presets and phonebook.
Just be smart and do it quickly
justatroll is offline   Reply With Quote
Old 01-13-2016, 01:56 PM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Is your battery clean (the terminals)?
Have a voltage meter/battery tester tool?
like this
Did you re-tighten battery terminals?
Try starting car with a different battery?
Can you take battery to local autoshop/O'rilleys/NAPA etc for testing?
Did you try reading the manual?
Did you recently do any car mods?
Are your fuses ok? Do you have a tool to check them?
Do any of your electric dependent items work like ac input? Lights? Car beeps?
I dont own a push start model (just not a big fan of all electric), but these are things I would check.
Later on, id check starter, alternator, etc...
Keep us posted!~
Yes, so ecu re-programs itself. Just unplug one cable while you work installing it. I know some people dont do this, they just plug and play.
Packofcrows is offline   Reply With Quote
The Following User Says Thank You to Packofcrows For This Useful Post:
Kkobe2 (01-13-2016)
Old 01-13-2016, 03:10 PM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
If you are referring to removing the negative terminal to do the install then no you don't have to worry. I have removed the negative terminal many times and it's good to go once i put the negative terminal back on.
Old 01-13-2016, 04:05 PM   #14
FR-Sky
FR-Sky's Avatar
Thanks guys!
Bad Emergency Jack? JDMenrique Issues | Warranty | Recalls / TSB 35 11-27-2015 07:55 PM
Emergency brake button?? Borzy Cosmetic Modification (Interior/Exterior/Lighting) 2 10-13-2015 08:18 PM
EMERGENCY I NEED HELP PLEASE kiname Southern California 25 07-09-2014 11:41 PM
ECUTEK ECU Emergency gdrider77 Software Tuning 6 12-18-2013 02:28 PM
Emergency help!! Howardwei Engine, Exhaust, Transmission 3 08-16-2013 04:42 PM
