CANADA Canada
Old 07-17-2014, 05:53 PM   #29
wheelhaus
wheelhaus's Avatar
Originally Posted by azian_advanced View Post
get gas from a place that doesn't contain any ethanol
/crickets
/thread
I understand many people have tried this without sufficient consistency to say its a hands down resolution. Some it worked, others no change.
wheelhaus is offline   Reply With Quote
Old 07-17-2014, 06:27 PM   #30
acro
Drives: GT-86
I should have added we only have e10 91 octane where I am. Shell vowed is what I usually use
acro is offline   Reply With Quote
Old 07-17-2014, 06:28 PM   #31
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Originally Posted by 1Cor10:23 View Post
I've mentioned this before but going to say it again...IMO, crickets are not detrimental to the operation of your car. However, running 91 octane on spirited driving (maybe even regular driving) will lower your IAM from knock. I've logged my IAM with Shell 91 before and it can get as low as .50. Now with Ultra94 it rarely goes below .9 on the street (has gone down to .7 at the track).
You're leaving a lot of timing on the table by running sub optimal gas.
IMO ethanol in a car not designed for it is "sub optimal" gas
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 07-17-2014, 06:31 PM   #32
1Cor10:23
1Cor10:23's Avatar
I can respect that, it's a trade off between two evils but I'd rather take ethanol, which isn't proven to harm the system vs. Knock, which is blatantly bad.
Old 07-17-2014, 06:57 PM   #33
wheelhaus
wheelhaus's Avatar
at sea level. At higher altitudes 91 is sufficient. However this is a little off topic...
Old 07-17-2014, 08:44 PM   #34
VirUzxZ
Drives: Black on Black on Black
just had my original pump replaced in june with what I assume to be their most recent and have crickets still. exclusively us shell 91
VirUzxZ is offline   Reply With Quote
Old 07-17-2014, 11:20 PM   #35
PMPB
Drives: BRZ Sport-tech
I ran Shell 91 exclusively from June 2013 to June 2014 and I had crickets basically the entire time. Not sure how all the others claim to have no crickets. IIRC it's a May 2013 build date.
I'm now doing 1 year on Petro94 exclusively. I can say for certain that that the crickets are RIDICULOUSLY worse. But I know for sure that I had them before.
PMPB is offline   Reply With Quote
Old 07-18-2014, 07:51 AM   #36
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Are you on stock ECU or aftermarket tune?
Isn't Subaru IAM value range 16?
krayzie is offline   Reply With Quote
Old 07-18-2014, 09:44 AM   #37
1Cor10:23
1Cor10:23's Avatar
I'm on aftermarket now but even on stock back in the day, you can hear the tip-in known happen under high load between 2-3K RPM. The stock tune isn't optimized for 91, it's 'safe' because your IAM will drop to adjust timing for the lower octane to counter the knock as best as it can.
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
krayzie (07-18-2014)
Old 07-18-2014, 10:05 AM   #38
krayzie
Drive From Home
krayzie's Avatar
Oh well not like I have a choice since I don't drive the car everyday. When the car sits in the garage for a week I would rather have E0 than E5/E10 in the fuel tank.
We need Chevron 94 E0 here in Ontario.
Old 07-18-2014, 10:28 AM   #39
sluflyer06
Drives: 2014 BRZ Ltd - DGM
They're likely never going to eliminate the crickets, I believe they've revised the fuel pump as many times as they are willing to. Just read another thread where user brought car in for updated pump, crickets came back, dealership called tech rep from Subaru and official position from Subaru is now that the noise is normal and there is no further fix.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-18-2014, 10:39 AM   #40
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
So how many people have gone aftermarket to fix the crickets, and to get more fuel flow for potential upgrades further down the line?
My dealership has a new pump on hand for me but I don't want to leave my car there for a whole day just to have the same problem again, or potentially worse, since my crickets are irregular and are not always present.
GotBRZ1691 is offline   Reply With Quote
Old 07-18-2014, 10:57 AM   #41
sluflyer06
I don't think I've read about any aftermarket HPFP's but are there any? Personally the crickets don't bother me, they started at about 200 miles on my car. I expect Subaru's to have some mechanical character.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 07-18-2014, 12:07 PM   #42
GotBRZ1691
GotBRZ1691's Avatar
I know Full Blown has one and im sure others do. I might start a thread and ask about it.
Changing fuel stops the chirp wbradley Issues | Warranty | Recalls / TSB 101 07-07-2014 05:46 PM
Dealer says power steering pump responsible for chirp joelg Issues | Warranty | Recalls / TSB 10 11-03-2013 09:54 AM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 03:40 PM
i hope the look of the frs doesn't change too much throughout the years... pr086 Scion FR-S / Toyota 86 GT86 General Forum 29 11-07-2012 02:21 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
